all4dom 101 Posted January 4 Posted January 4 (edited) So i want to put light strips in a.new entertainment console i purchased & im bitbsire how i can run the light strip across the inside top & bottom shelf becasue there is the middle board inside for support there isnt any type of opening i can run the strip across. I dont want to do 4 strips for top & bottom for each side & its compressed wood so im not sure if I can drill a hole in it. I purchased sengled zigbee lights strips because i use samsung smartthings but I can get a different brand if it has something to.let me curve around the middle board through the back. I really can use some help. Thanks Dom Edited January 4 by all4dom Typo
Luke 42233 Posted January 5 Posted January 5 I think @chef has a lot of experience with this sort of thing.
