justinrh 270 Posted January 8 Author Posted January 8 Well, there were some in the original data (that I did not add myself) but was copied to the new folder. I'll delete and retry.
justinrh 270 Posted January 8 Author Posted January 8 Deleting those JPGs in Music2 did not lead to an image after rescan.
Gilgamesh_48 1244 Posted January 8 Posted January 8 7 minutes ago, justinrh said: Deleting those JPGs in Music2 did not lead to an image after rescan. Maybe use "refresh metadata" rather that a simple scan.
justinrh 270 Posted January 8 Author Posted January 8 (edited) To be sure, after I deleted the JPGs from Music2, I copied it to Music3 and created a new library but still no image. embyserver.txt 40 minutes ago, Gilgamesh_48 said: Maybe use "refresh metadata" rather that a simple scan. I tried that on Music3 and no diff (and it would be the same as the initial library creation). Edited January 8 by justinrh
sa2000 703 Posted January 8 Posted January 8 @justinrhI think it would be best if i do my own testing using some of your files. Could you make two albums available to me for 2 artists - so one each and I will do tests with them. I will send you an upload link 1
sa2000 703 Posted January 9 Posted January 9 Thank You. I have reproduced the issue and referred it to the development team Compared with a movies library where we logged this as debug Debug ImageProcessor: Creating image collage and saving to <Path> There was no evidence of that being done for the music library 2
justinrh 270 Posted January 9 Author Posted January 9 10 hours ago, sa2000 said: I have reproduced the issue and referred it to the development team Thank you so much @sa2000 You are awesome! 1
