graytinc 1 Posted January 20 Posted January 20 11:17:10 AM Failed for tv: Emby API error: 400 Bad Request 11:17:10 AM Processing STRM for Salome... 11:17:10 AM Failed for Salome: Emby API error: 400 Bad Request 11:17:10 AM Processing STRM for Admin... 11:17:10 AM Failed for Admin: Emby API error Seems it's not working either!
TheGru 149 Posted January 20 Author Posted January 20 You have a path issue, that is the only explanation. Go to admin / setttings /setup tab and check your paths. DO NOT JUST BLINDLY ENTER MY PATHS FROM THE IMAGE
DaMoekster 5 Posted January 20 Posted January 20 Is anyone having the text field loose focus in the playlist section? The last couple of versions I have to click the textfield after every letter I type. I tested on multiple pc’s, phones and browsers.
graytinc 1 Posted January 20 Posted January 20 That is my Emby library structure, but I did not create an access folder path in the Emby dashboard. Thats my docker settings
TheGru 149 Posted January 20 Author Posted January 20 53 minutes ago, DaMoekster said: Is anyone having the text field loose focus in the playlist section? The last couple of versions I have to click the textfield after every letter I type. I tested on multiple pc’s, phones and browsers. i know what you are experiencing, but can you provide a screenshot of the exact input to help me target a fix?
TheGru 149 Posted January 20 Author Posted January 20 Just now, TheGru said: i know what you are experiencing, but can you provide a screenshot of the exact input to help me target a fix? I found it! 1
DaMoekster 5 Posted January 20 Posted January 20 Just to be sure, it's every text field when creating a playlist. Thanks!
TheGru 149 Posted January 20 Author Posted January 20 1 minute ago, DaMoekster said: Just to be sure, it's every text field when creating a playlist. Thanks! yep its a debounce issue 1
TheGru 149 Posted January 20 Author Posted January 20 Aperture v0.6.4 Release Notes Quick patch release to fix an annoying input bug in the New Playlist modal. Thank you @DaMoekster Bug Fixes Fixed: Input Fields Losing Focus in New Playlist Modal When creating or editing a playlist, typing in any input field (Preferences, Playlist Name, Description) would cause the cursor to jump out of the field after each character. This made it impossible to type normally. Root cause: The Section and AIButton helper components were defined inside the parent component, causing React to treat them as new components on every keystroke and unmount/remount the inputs. Fix: Moved these components outside the parent function so they maintain stable references across renders. Update Instructions For Docker Users # Pull the latest image docker compose pull # Restart with new version docker compose up -d Full Changelog Bug Fixes: fix: input fields losing focus in playlist modal due to inline component definitions 1
DaMoekster 5 Posted January 20 Posted January 20 Yes, working! Thanksfor the quick response @TheGru 1
akacharos 31 Posted January 21 Posted January 21 (edited) Can we decouple the Aperture <-> Emby server connection URL from the public facing Emby URL? In my setup for example, Aperture connects to Emby locally via http://host.docker.internal:8096. But that breaking the "Open in Emby" links. Edited January 21 by akacharos
TheGru 149 Posted January 21 Author Posted January 21 1 minute ago, akacharos said: Can we decouple the Aperture <-> Emby server connection URL from the public facing Emby URL? In my setup for example, Aperture connects to Emby locally via http://host.docker.internal:8096. But that breaking the "Open in Emby" links. Use the actual IP address of your Emby server instead. It should work
akacharos 31 Posted January 21 Posted January 21 Maybe a few points for clarification. My Emby instance is currently publicly accessible via an HTTPS domain managed by a Caddy reverse proxy. When I enter this domain URL into the "Server URL" field in Aperture, everything works fine, including the "Open in Emby" links. However, this configuration forces all communication between Aperture and Emby to travel over the internet—traveling from Aperture to the router, through my ISP, to a DNS resolver, and back through the router to Caddy. Ideally, Aperture and Emby should communicate locally to avoid the unnecessary overhead and latency of this NAT hairpinning/round trip. That's why I suggested adding an optional "External Server URL" field to be used specifically for constructing the "Open in Emby" links, while allowing the primary connection to remain local. 1
TheGru 149 Posted January 21 Author Posted January 21 2 hours ago, akacharos said: Maybe a few points for clarification. My Emby instance is currently publicly accessible via an HTTPS domain managed by a Caddy reverse proxy. When I enter this domain URL into the "Server URL" field in Aperture, everything works fine, including the "Open in Emby" links. However, this configuration forces all communication between Aperture and Emby to travel over the internet—traveling from Aperture to the router, through my ISP, to a DNS resolver, and back through the router to Caddy. Ideally, Aperture and Emby should communicate locally to avoid the unnecessary overhead and latency of this NAT hairpinning/round trip. That's why I suggested adding an optional "External Server URL" field to be used specifically for constructing the "Open in Emby" links, while allowing the primary connection to remain local. Ahh now I understand the request
graytinc 1 Posted January 21 Posted January 21 I need help with folders, I have attached my current setup.
GoldSpacer 11 Posted January 22 Posted January 22 I ran into a maybe rare bug? I have an Emby user account that 2 users used, I split them up and renamed the original user from D to C, then named the new one D, this is because C mainly used the original account and I wanted to preserve their watch history. Syncing the users from the admin > users page shows the new names correctly, but the generate recommendations job and the build aperture libraries job show both users as D, and the library folders are both built as D. Does the database need to update the user names if the name changes via user sync?
graytinc 1 Posted January 22 Posted January 22 @TheGruAperture uses Linux container paths (/mnt/...) when talking to Emby, but Windows Emby cannot access these paths, causing library sync failures. error from Emby on Windows 2026-01-21 20:15:00.069 Info LibraryStructureService-0HNINOE5FF6UA:00000002: http/1.1 POST http://10.10.10.3:8096/Library/VirtualFolders?name=Shows Admin Watches&collectionType=tvshows&paths=/mnt/ApertureLibraries/aperture-watching/Admin_9dce44c8e806446d9a982217b0d229d8&refreshLibrary=true. Source Ip: host10, UserAgent: node 2026-01-21 20:15:00.070 Error LibraryStructureService-0HNINOE5FF6UA:00000002: Error processing request
Raichi 4 Posted January 22 Posted January 22 Just an update for easy installation in Unraid. Both applications are available now in the CA store. Aperture & Pgvector. 1
FlameRed 2 Posted January 22 Posted January 22 I hesitate to report this, but during the last day or so, I now see duplicates of two TV Series under Continue Watching. It is very strange as I have not seen duplicates under Continue Watching before. I am thinking it possibly a coincident with the installation of the latest release of Aperture but I am not sure. Just reporting it in-case others see it. Very strange.
TheGru 149 Posted January 22 Author Posted January 22 3 hours ago, Raichi said: Just an update for easy installation in Unraid. Both applications are available now in the CA store. Aperture & Pgvector. WOW Awesome and thank you! 1
TheGru 149 Posted January 22 Author Posted January 22 12 hours ago, graytinc said: @TheGruAperture uses Linux container paths (/mnt/...) when talking to Emby, but Windows Emby cannot access these paths, causing library sync failures. error from Emby on Windows 2026-01-21 20:15:00.069 Info LibraryStructureService-0HNINOE5FF6UA:00000002: http/1.1 POST http://10.10.10.3:8096/Library/VirtualFolders?name=Shows Admin Watches&collectionType=tvshows&paths=/mnt/ApertureLibraries/aperture-watching/Admin_9dce44c8e806446d9a982217b0d229d8&refreshLibrary=true. Source Ip: host10, UserAgent: node 2026-01-21 20:15:00.070 Error LibraryStructureService-0HNINOE5FF6UA:00000002: Error processing request Can another Windows user who got up and running help out here? I am now bogged down on a work project but do not want to leave anyone hanging.
TheGru 149 Posted January 22 Author Posted January 22 12 hours ago, graytinc said: @TheGruAperture uses Linux container paths (/mnt/...) when talking to Emby, but Windows Emby cannot access these paths, causing library sync failures. error from Emby on Windows 2026-01-21 20:15:00.069 Info LibraryStructureService-0HNINOE5FF6UA:00000002: http/1.1 POST http://10.10.10.3:8096/Library/VirtualFolders?name=Shows Admin Watches&collectionType=tvshows&paths=/mnt/ApertureLibraries/aperture-watching/Admin_9dce44c8e806446d9a982217b0d229d8&refreshLibrary=true. Source Ip: host10, UserAgent: node 2026-01-21 20:15:00.070 Error LibraryStructureService-0HNINOE5FF6UA:00000002: Error processing request There is a really detailed Docker Compose file for Windows users. I know it works as I have gotten 2 other people and it was created as a result of those conversations. Have you reviewed it?
DaMoekster 5 Posted January 22 Posted January 22 13 hours ago, graytinc said: @TheGruAperture uses Linux container paths (/mnt/...) when talking to Emby, but Windows Emby cannot access these paths, causing library sync failures. error from Emby on Windows 2026-01-21 20:15:00.069 Info LibraryStructureService-0HNINOE5FF6UA:00000002: http/1.1 POST http://10.10.10.3:8096/Library/VirtualFolders?name=Shows Admin Watches&collectionType=tvshows&paths=/mnt/ApertureLibraries/aperture-watching/Admin_9dce44c8e806446d9a982217b0d229d8&refreshLibrary=true. Source Ip: host10, UserAgent: node 2026-01-21 20:15:00.070 Error LibraryStructureService-0HNINOE5FF6UA:00000002: Error processing request During the setup you need to tell aperture where you created the ApertureLibrary folder the way Emby sees it. For example: I created a folder on my E:drive. This folder is readable and writable for emby. So during the setup I filled in E:|ApertureLibraries\ in the library parth. If you choose for Apterure to create strm files for your ai recommendations and top picks you can ignore the "media serverpath prefix" during setup. Make sure you select strm for tvshows because tvshows are defaulted to create symlinks.
Neminem 1583 Posted January 22 Posted January 22 1 hour ago, FlameRed said: I hesitate to report this, but during the last day or so, I now see duplicates of two TV Series under Continue Watching. It is very strange as I have not seen duplicates under Continue Watching before. I am thinking it possibly a coincident with the installation of the latest release of Aperture but I am not sure. Just reporting it in-case others see it. Very strange. No it not strange, its a know issue. And today no one has found the solution. Scroll through this post, and see why, then search the forum, and find more info.
ebr 16299 Posted January 22 Posted January 22 35 minutes ago, Neminem said: And today no one has found the solution. There will be one forthcoming. 5
