thunderclap 52 Posted January 3 Posted January 3 (edited) I think this is what I'm experiencing too, especially after pausing and then resuming. The image pixelates and will stop playing every 5 min. or so forcing me to back out and start again. Very frustrating. I hope it can be fixed quickly. I've attached my log in case it helps. ffmpeg-transcode-2795c7cb-54ea-4e49-a25c-ae9bcc2c3370_1.txt Edited January 3 by thunderclap
Solution Luke 42238 Posted January 3 Solution Posted January 3 @thunderclapit is transcoding due to your quality setting. Maybe you still have the quality set too high and need to lower it even further? 1
thunderclap 52 Posted January 6 Author Posted January 6 On 1/2/2026 at 10:40 PM, Luke said: @thunderclapit is transcoding due to your quality setting. Maybe you still have the quality set too high and need to lower it even further? It was set too low, perhaps. Not sure who changed it (maybe one of my kids). I bumped it back up so it'll do direct play and let you know if I continue to have problems. 1
