Audio Track Selection
Spaceboy
Hopefully an easy one. I have a video with two audio tracks in one DTS and the other AC3 DD+, both english, the AC3 track is the directors commentary, the DTS track is marked as default.
MB3 always selects the AC3 track to play back in the web browser even though both are playable. i expected it would go for the highest quality or default one but it does not. have i previously set something that means its behaving this way and where should i look to change that?
or should i just set the user to use default tracks always? it seems that there's going to be some downside to this though.
cheers
