sa2000 697 Posted January 14 Posted January 14 11 minutes ago, sa2000 said: The two local network IP addresses being detected now are 10.32.0.6 (the vpn one) and 192.168.1.15 and emby server successfully accessed both through local port 8096 2026-01-14 17:42:06.348 Debug App: Ping test result to http://192.168.1.15:8096/system/ping. Success: True 2026-01-14 17:42:06.350 Debug App: Ping test result to http://10.32.0.6:8096/system/ping. Success: True
sa2000 697 Posted January 21 Posted January 21 On 14/01/2026 at 17:53, luckyluca said: Ok, I managed to add a 20-second sleep ahead of emby-server starting up. That takes care of the internet access after reboot. Did this change to allow for the local network to be detected on launch resolve the issue?
sa2000 697 Posted January 21 Posted January 21 Just thinking again about this .. You had folders for "TV Series" library on the remote network mounted path and these were not getting removed, but similar remote network mounted paths for the Movies library were being removed. This "TV Series" Folder path did not get removed: /mnt/wd_black/Downloads/plex_media/Series This "Movies" Folder path did get removed: /mnt/wd_black/Downloads/plex_media/Films Wondering how the mounts are setup - Would they be individually mounted or just mounted at higher level and then sub-folder names appended to the mount path - so would be the same mount for both TV Series and Movies but accessing different sub-folders below the mounts
luckyluca 2 Posted January 21 Author Posted January 21 7 hours ago, sa2000 said: Just thinking again about this .. You had folders for "TV Series" library on the remote network mounted path and these were not getting removed, but similar remote network mounted paths for the Movies library were being removed. This "TV Series" Folder path did not get removed: /mnt/wd_black/Downloads/plex_media/Series This "Movies" Folder path did get removed: /mnt/wd_black/Downloads/plex_media/Films Wondering how the mounts are setup - Would they be individually mounted or just mounted at higher level and then sub-folder names appended to the mount path - so would be the same mount for both TV Series and Movies but accessing different sub-folders below the mounts No, they all got removed, all paths got removed. If you check my initial messages, after the issue, I recreated all of them, but not the movie library. I now recreated the movie's library. So far, everything is good. I also created a backup using the backup-restore page. I plan on replicating the same conditions as prior next: unplugging the HDD, turning on the minipc again, turning on wifi and connecting via wifi. And see if that causes any problem. The minipc now has a static IP address (ending in .15). I added the 20-second sleep before launching the server to allow for the network to start up and stabilise. Question: Is this log showing the network solved now? 2026-01-21 11:53:17.150 Info NetworkManager: Detecting local network addresses 2026-01-21 11:53:17.151 Info NetworkManager: networkInterface: Ethernet enp2s0, Speed: 1000000000, Description: enp2s0 2026-01-21 11:53:17.152 Info NetworkManager: GatewayAddresses: 192.168.1.1,192.168.1.1 2026-01-21 11:53:17.155 Info NetworkManager: UnicastAddresses: 192.168.1.15,fe80::7270:fcff:fe08:f32%2 2026-01-21 11:53:17.155 Info NetworkManager: networkInterface: Loopback lo, Speed: -1, Description: lo 2026-01-21 11:53:17.155 Info NetworkManager: GatewayAddresses: 2026-01-21 11:53:17.155 Info NetworkManager: UnicastAddresses: 127.0.0.1,::1 2026-01-21 11:53:17.155 Info NetworkManager: networkInterface: Unknown tun0, Speed: -1, Description: tun0 2026-01-21 11:53:17.155 Info NetworkManager: GatewayAddresses: 10.32.0.5,10.32.0.5,10.32.0.5 2026-01-21 11:53:17.155 Info NetworkManager: UnicastAddresses: 10.32.0.6,fe80::f2a2:72b9:dc72:4fce%4 2026-01-21 11:53:17.168 Info NetworkManager: Detected local ip addresses: [{"IPAddress":"192.168.1.15","HasGateWayAddress":true,"PrefixLength":24,"IPv4Mask":"255.255.255.0"},{"IPAddress":"10.32.0.6","HasGateWayAddress":true,"PrefixLength":32,"IPv4Mask":"255.255.255.255"},{"IPAddress":"fe80::7270:fcff:fe08:f32%2","HasGateWayAddress":true,"PrefixLength":64},{"IPAddress":"fe80::f2a2:72b9:dc72:4fce%4","HasGateWayAddress":true,"PrefixLength":64},{"IPAddress":"127.0.0.1","HasGateWayAddress":false,"PrefixLength":8,"IPv4Mask":"255.0.0.0"},{"IPAddress":"::1","HasGateWayAddress":false,"PrefixLength":128}] 2026-01-21 11:53:17.171 Info App: Adding HttpListener prefix http://+:8096/
sa2000 697 Posted January 22 Posted January 22 Thank You. We never had any logs covering the actual removals - we just had logs showing the aftermath. Maybe there will be some clues with debug logging enabled. Try to save all log files covering from launch time up to time when the media gets removed from the database Thanks
luckyluca 2 Posted February 25 Author Posted February 25 Update: There hasn't been any problem since. I also replicated the steps taken when bringing the miniPC with me (unplugged the media storage HDD and switching to Wifi). For now, everything is working top-notch. I'm leaving debug log on and 7 days retention just in case. I also enabled the backup/restore plugin and regularly backup the database, just in case. I'm happy to consider it sorted for now 2
