italianar15 0 Posted January 1 Posted January 1 (edited) Environment: Server Version: [Insert Emby Version, e.g., 4.8.10.0] Host OS: Linux / Ubuntu 24.04 LTS (Kernel 6.8.0-90-generic) Deployment: Docker (Portainer) Privileged Mode: Yes (privileged: true) GPU: AMD Radeon RX 7600 (RDNA3) OpenCL: OpenCL 2.1 AMD-APP (3581.0) Driver: Mesa 25.0.7-0ubuntu0.24.04.2 (Noble Updates) Hardware transcoding (VAAPI) for standard H.264/HEVC works correctly, but Hardware Tone Mapping (HDR -> SDR) fails on the RX 7600. Configuration: I am running the container in privileged mode with the following environment variables to force RDNA3 compatibility: LIBVA_DRIVER_NAME=radeonsi HSA_OVERRIDE_GFX_VERSION=11.0.0 (To force ROCm/OpenCL compatibility for RDNA3) Symptoms: When Tone Mapping is enabled, the ffmpeg process crashes immediately or falls back to software transcoding. clinfo confirms the OpenCL runtime is present, but the interop between VAAPI and OpenCL for RDNA3 seems broken despite the HSA override. Steps Taken: Verified Drivers: Confirmed mesa-va-drivers (v25.0.7) are installed. Verified OpenCL: clinfo confirms OpenCL 3.0/2.1 availability. Applied RDNA3 Workarounds: Added HSA_OVERRIDE_GFX_VERSION=11.0.0 to the container environment. Isolated Issue: Disabling "Enable Tone Mapping" allows HW transcoding to proceed, confirming the GPU is accessible. Hardware Check: System has an Intel iGPU (renderD128), but Emby is configured to use the discrete AMD card (renderD129) and LIBVA_DRIVER_NAME is hard-set to radeonsi. -Gemini In my words. With hw enabled for tone mapping it doesn't even attempt to use the GPU. When I pull the transcode logs with it enabled you can see emby never attempts to use it. The web is littered with asks for better AMD support within Emby. Is this something that still on the roadmap? Nvidia is ridiculously expensive compared to solid RDNA3 cards. Thanks Edited January 1 by italianar15 Fixed Title
Luke 42242 Posted January 8 Posted January 8 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Luke 42242 Posted January 8 Posted January 8 Also we will have some updates on the beta channel in the near future so stay tuned for that.
italianar15 0 Posted January 10 Author Posted January 10 Server Version: Emby Server 4.9.3.0 OS: Linux 6.8.0-90-generic (Ubuntu 24.04 base), x64 Install Type: Docker Client: Emby Web 4.9.3.0 on Firefox (Windows 10) Hardware Acceleration: VAAPI enabled (Advanced mode) Playback fails when Emby attempts hardware transcoding for certain HDR/Dolby Vision titles. Emby starts ffmpeg, but the hardware transcode fails immediately. Emby then retries and falls back to software transcoding, which works. This appears tied to the HDR tone mapping path using tonemap_opencl, which fails with an OpenCL platform/device error. What I was trying to do Play a 4K HDR/Dolby Vision movie from Emby Web. The client triggers transcoding due to audio codec support limitations. Steps to Reproduce Select a 4K Dolby Vision / HDR10 title Click Play Playback fails / returns 500 error on HLS segment request Server log shows ffmpeg hardware transcode failure, then software fallback Example media Example file path in container: /Media/Movies/TRON Legacy (2010)/TRON Legacy (2010) - IMAX.mkv Video: HEVC Main 10, 3840x2160, Dolby Vision profile 8.1 (HDR10 compatible), BT.2020, PQ Audio: EAC3 Atmos 5.1 Subtitles: SRT + multiple PGS tracks Expected Result Hardware transcoding should succeed using VAAPI (including tone mapping if needed). Actual Result Hardware transcode fails immediately with OpenCL errors. The key ffmpeg errors include: Failed to get number of OpenCL platforms: -1001 Failed to created derived device context: -19 Error reinitializing filters! Failed to inject frame into filter network: No such device Conversion failed! Emby then logs that the transcode attempt failed and falls back to software transcoding, which works. Additional Notes FFmpeg also shows warnings about PGS subtitle stream probing (“unspecified size” / analyzeduration / probesize), but the failure happens during OpenCL tone mapping device creation (VAAPI → OpenCL) before segment output starts. --Gemini
Luke 42242 Posted January 10 Posted January 10 2 hours ago, italianar15 said: Server Version: Emby Server 4.9.3.0 OS: Linux 6.8.0-90-generic (Ubuntu 24.04 base), x64 Install Type: Docker Client: Emby Web 4.9.3.0 on Firefox (Windows 10) Hardware Acceleration: VAAPI enabled (Advanced mode) Playback fails when Emby attempts hardware transcoding for certain HDR/Dolby Vision titles. Emby starts ffmpeg, but the hardware transcode fails immediately. Emby then retries and falls back to software transcoding, which works. This appears tied to the HDR tone mapping path using tonemap_opencl, which fails with an OpenCL platform/device error. What I was trying to do Play a 4K HDR/Dolby Vision movie from Emby Web. The client triggers transcoding due to audio codec support limitations. Steps to Reproduce Select a 4K Dolby Vision / HDR10 title Click Play Playback fails / returns 500 error on HLS segment request Server log shows ffmpeg hardware transcode failure, then software fallback Example media Example file path in container: /Media/Movies/TRON Legacy (2010)/TRON Legacy (2010) - IMAX.mkv Video: HEVC Main 10, 3840x2160, Dolby Vision profile 8.1 (HDR10 compatible), BT.2020, PQ Audio: EAC3 Atmos 5.1 Subtitles: SRT + multiple PGS tracks Expected Result Hardware transcoding should succeed using VAAPI (including tone mapping if needed). Actual Result Hardware transcode fails immediately with OpenCL errors. The key ffmpeg errors include: Failed to get number of OpenCL platforms: -1001 Failed to created derived device context: -19 Error reinitializing filters! Failed to inject frame into filter network: No such device Conversion failed! Emby then logs that the transcode attempt failed and falls back to software transcoding, which works. Additional Notes FFmpeg also shows warnings about PGS subtitle stream probing (“unspecified size” / analyzeduration / probesize), but the failure happens during OpenCL tone mapping device creation (VAAPI → OpenCL) before segment output starts. --Gemini Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
italianar15 0 Posted January 10 Author Posted January 10 Sorry, thought I followed that template...? Forgot the logfiles, though. ffmpeg-transcode.log embyserver.log
