Asazen 8 Posted December 30, 2025 Posted December 30, 2025 All the trailers are in English. How can I get them in my language? The plugin doesn't have that option. There are also tons of trailers that won't play with the following error, and I ended up disabling the Trailers plugin: Playback Error: Currently, no compatible streams are available. Please try again later or contact your system administrator for more details.
Luke 42288 Posted December 30, 2025 Posted December 30, 2025 58 minutes ago, Asazen said: All the trailers are in English. How can I get them in my language? The plugin doesn't have that option. There are also tons of trailers that won't play with the following error, and I ended up disabling the Trailers plugin: Playback Error: Currently, no compatible streams are available. Please try again later or contact your system administrator for more details. What version of the server are you on?
Asazen 8 Posted December 30, 2025 Author Posted December 30, 2025 (edited) 43 minutes ago, Luke said: What version of the server are you on? 4.9.1.90 Edited December 30, 2025 by Asazen
Luke 42288 Posted December 30, 2025 Posted December 30, 2025 OK. Let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Asazen 8 Posted December 30, 2025 Author Posted December 30, 2025 1 hour ago, Luke said: OK. Let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! I had it disabled because it wasn't working, but I enabled it again and played 2 or 3 trailers and none of them worked in this case, but that error doesn't appear in all of them. embyserver.txt
Asazen 8 Posted January 3 Author Posted January 3 (edited) Did you check the log? I'm just asking if you want to fix it. I don't care if I deactivated the plugin; I'm not interested if it's not in my language. What I don't understand is, if you sell a product globally, why isn't everything adapted globally as well? We all pay for it; we all have the same rights, right? This isn't a complaint, it's a suggestion. On another note, I noticed that this error only appears on Emby Web. It works correctly on Android TV (although only in English...). If you need any further testing to fix it, let me know. Otherwise, you can close the thread. Regards. Edited January 3 by Asazen
Luke 42288 Posted January 3 Posted January 3 13 hours ago, Asazen said: Did you check the log? I'm just asking if you want to fix it. I don't care if I deactivated the plugin; I'm not interested if it's not in my language. What I don't understand is, if you sell a product globally, why isn't everything adapted globally as well? We all pay for it; we all have the same rights, right? This isn't a complaint, it's a suggestion. On another note, I noticed that this error only appears on Emby Web. It works correctly on Android TV (although only in English...). If you need any further testing to fix it, let me know. Otherwise, you can close the thread. Regards. OK currently the trailers will be in English. I think that is the next improvement to the Trailer plugin that we can look at making. Thanks.
