hawkguru 4 Posted December 26, 2025 Posted December 26, 2025 i have changed all my library folders to movie view by default one by one, but one is stubborn, while I can successfully choose "Movies" as default view under homescreen, and it stays that way after a restart, going on that library shows TV Show view... 1
GrimReaper 4926 Posted December 26, 2025 Posted December 26, 2025 (edited) Do you have any movies in that particular library? Which server version? Edit: I can reproduce that on 4.9.1.90: Mixed-content library, selecting either "Movies" or "Shows" tab as landing page - both lead to "Shows" tab library view. @Luke Edited December 26, 2025 by GrimReaper Test 1
GrimReaper 4926 Posted December 26, 2025 Posted December 26, 2025 1 minute ago, Luke said: Are you saying you have both tabs? Yes, and selecting either of them as Default screen in Home Screen settings results in "Shows" tab to be landing page. 1
hawkguru 4 Posted December 26, 2025 Author Posted December 26, 2025 (edited) Thank you. I also have "Mixed content" selected for all my folders, so out of 20 folders, this one is the only stubborn one...setting the default view to Movie for the rest defaults them to Movie when I select them. Edited December 26, 2025 by hawkguru
Happy2Play 9814 Posted December 26, 2025 Posted December 26, 2025 Yes I see the same results as OP on 4.9.1.90, only affect Movie default screen option. I guess you can say it is somewhat broke in beta 4.9.4.1 also with the combine tab as there is only one option not two. 1
Luke 42288 Posted December 26, 2025 Posted December 26, 2025 OK the next release will be merging those tabs anywaybe. 1
