Neminem 1625 Posted January 22 Posted January 22 3 minutes ago, yocker said: Would you want me to make this EmbyCredit with support for PaddleOCR the default? Definitely no to that, you will have to deal with people, that does not have a Nvidia GPU with at least 8GB VRAM. Mine does have problems if images size are to high, and its even worst on series that are in 4K resolution. But new commers will not understand this and complain about it when using a Nvidia card with > 8GB. 9 minutes ago, yocker said: POOL_DEFAULT_MIN=2 POOL_DEFAULT_MAX=6 POOL_DEFAULT_IDLETIMEOUTMILLIS=10000 POOL_DEFAULT_EVICTIONRUNINTERVALMILLIS=5000 I will do a test with this 1
yocker 1423 Posted January 22 Author Posted January 22 3 minutes ago, Neminem said: Definitely no to that, you will have to deal with people, that does not have a Nvidia GPU with at least 8GB VRAM. Mine does have problems if images size are to high, and its even worst on series that are in 4K resolution. But new commers will not understand this and complain about it when using a Nvidia card with > 8GB. You are most likely right, it would likely confuse some and think the plugin is broken. I will see if i can some up with a solution, maybe keep it as a custom plugin with warnings every where. That said, if any one else have anything to say about it then please do, i aim to please! 1
Neminem 1625 Posted January 22 Posted January 22 Well that's something new With those tweaks I looks better. Lets see when done 1
yocker 1423 Posted January 22 Author Posted January 22 11 minutes ago, Neminem said: Well that's something new With those tweaks I looks better. Lets see when done I seriously need to do something about the confidence counter as well. 1
Neminem 1625 Posted January 22 Posted January 22 Jep all I ever see is 95% None above or below. Its ether fail or 95% 1 1
Neminem 1625 Posted January 22 Posted January 22 Same series with new docker tweaks. Start time 15:39 Finish time 16:24 Total time 45 min 2026-01-22 15:39:16.713 Info CreditsDetectionApiService: Series found: Millennium, InternalId: 128621 2026-01-22 15:39:16.724 Info CreditsDetectionApiService: Found 67 episodes for series InternalId: 128621 (excluded 1 specials) 2026-01-22 15:39:16.724 Info Plugin: Cleared in-memory batch detection cache and processing queue for fresh detection 2026-01-22 15:39:16.724 Info Plugin: Queued 67 episodes for processing (forced reprocess). Queue size: 67 2026-01-22 16:24:19.781 Info Plugin: Processing complete: 67 succeeded, 0 failed It started fast and furious, but had a stall, and recovered to continue. 1
yocker 1423 Posted January 22 Author Posted January 22 (edited) 4 minutes ago, Neminem said: Same series with new docker tweaks. Start time 15:39 Finish time 16:24 Total time 45 min 2026-01-22 15:39:16.713 Info CreditsDetectionApiService: Series found: Millennium, InternalId: 128621 2026-01-22 15:39:16.724 Info CreditsDetectionApiService: Found 67 episodes for series InternalId: 128621 (excluded 1 specials) 2026-01-22 15:39:16.724 Info Plugin: Cleared in-memory batch detection cache and processing queue for fresh detection 2026-01-22 15:39:16.724 Info Plugin: Queued 67 episodes for processing (forced reprocess). Queue size: 67 2026-01-22 16:24:19.781 Info Plugin: Processing complete: 67 succeeded, 0 failed It started fast and furious, but had a stall, and recovered to continue. Wonder what that stall is. The plugin should wait patiently like a good boy for the tesseract. Will look into seeing if i can improve it a little. 45 minutes reduction is very nice! Maybe a little "readme" on the front page here would be in order. Edited January 22 by yocker
Neminem 1625 Posted January 22 Posted January 22 (edited) 11 minutes ago, yocker said: 45 minutes reduction is very nice! Maybe a little "readme" on the front page here would be in order. That's true almost halv the time. It stalled after the first 2, and recovered but never got fully up to speed again. It looks as if the docker was overloaded, but it did not restart. Created means I made the tweaks to the docker. Edited January 22 by Neminem
yocker 1423 Posted January 22 Author Posted January 22 5 hours ago, Neminem said: That's true almost halv the time. It stalled after the first 2, and recovered but never got fully up to speed again. It looks as if the docker was overloaded, but it did not restart. Created means I made the tweaks to the docker. Will look into if there's anything i can do, wouldn't get my hopes up though as suspect you are right and it might be we found the limit to tesseract with your system.
rechigo 367 Posted January 23 Posted January 23 Anyone else experiencing issues with QSV? It just immediately fails with no credits found... not seeing anything in the logs pointing to any real errors. I tried specifying the specific card as well (/dev/dri/card0, /dev/dri/renderD128) which both have the same result I would like to note VAAPI works fine... I prefer to use QSV because I find it to be slightly higher performance in the applications I've tested. in case I missed something, debug logs: credits-detection-debug-2026-01-23T02-14-11.log
yocker 1423 Posted January 24 Author Posted January 24 23 hours ago, rechigo said: Anyone else experiencing issues with QSV? It just immediately fails with no credits found... not seeing anything in the logs pointing to any real errors. I tried specifying the specific card as well (/dev/dri/card0, /dev/dri/renderD128) which both have the same result I would like to note VAAPI works fine... I prefer to use QSV because I find it to be slightly higher performance in the applications I've tested. in case I missed something, debug logs: credits-detection-debug-2026-01-23T02-14-11.log 15.3 kB · 0 downloads @NeminemYou had intel right? Does it work for you?
Neminem 1625 Posted January 24 Posted January 24 (edited) @yockerTesting it now QSV test : Hmm with QSV they all fail. credits-detection-debug-2026-01-24T07-33-34.log VAAPI test : credits-detection-debug-2026-01-24T07-46-46.log VAAPI is working fine. QSV issue in Emby's drivers I guess. And here are server logs, with debug enabled. embyserver (15).txt Edited January 24 by Neminem 1
yocker 1423 Posted January 24 Author Posted January 24 1 minute ago, Neminem said: @yockerTesting it now QSV test : Hmm with QSV they all fail. credits-detection-debug-2026-01-24T07-33-34.log 18.62 kB · 0 downloads VAAPI test : credits-detection-debug-2026-01-24T07-46-46.log 19.4 kB · 0 downloads VAAPI is working fine. QSV issue in Emby's drivers I guess. And here are server logs, with debug enabled. embyserver (15).txt 2.38 MB · 0 downloads Thank you, will look into it.
yocker 1423 Posted January 24 Author Posted January 24 (edited) On 1/23/2026 at 3:17 AM, rechigo said: Anyone else experiencing issues with QSV? It just immediately fails with no credits found... not seeing anything in the logs pointing to any real errors. I tried specifying the specific card as well (/dev/dri/card0, /dev/dri/renderD128) which both have the same result I would like to note VAAPI works fine... I prefer to use QSV because I find it to be slightly higher performance in the applications I've tested. in case I missed something, debug logs: credits-detection-debug-2026-01-23T02-14-11.log 15.3 kB · 0 downloads After testing (Thanks @Neminem) it seems like it might not be the plugin that has a problem but the ffmpeg that Emby uses and/or Emby it self. I will keep looking at it but don't think there's much i can do. Edited January 24 by yocker 1
rechigo 367 Posted January 24 Posted January 24 5 hours ago, yocker said: After testing it seems like it might not be the plugin that has a problem but the ffmpeg that Emby uses and/or Emby it self. I will keep looking at it but don't think there's much i can do. I had a feeling considering I had other issues with QSV a few months ago and we were just told we have to wait for the new FFmpeg version.... not sure when thats coming out
yocker 1423 Posted January 26 Author Posted January 26 (edited) New version out (1.6.9.0) on yocksers/EmbyCredits github Added: Image Preprocessing Contrast enhancement (adjustable 0.5-3.0) Brightness adjustment (adjustable -0.5 to 0.5) Sharpening filter with configurable strength Region of Interest (ROI) Detection Focus OCR analysis on specific screen regions Options: Full Frame, Bottom Third, Bottom Half, Center, Top Third Reduces processing time and improves accuracy for specific layouts Note: Not recommended unless uses for re-detecting videos that otherwise failed. Fuzzy Keyword Matching Levenshtein distance algorithm for detecting misspelled/partial keywords Configurable maximum edit distance (default: 2) Catches OCR errors like "Director" → "Dlrector" Scrolling Credits Detection Detects text position changes across consecutive frames Identifies scrolling credits by tracking vertical movement Configurable window size and position threshold Adaptive Frame Rate Dynamically adjusts frame sampling based on text density Automatically speeds up/slows down analysis Credit Structure Detection Identifies role-name patterns (e.g., "Director: John Doe") Recognizes structured credit layouts Configurable role patterns and minimum role count Quick Preset Buttons Best Quality: Optimized for accuracy Best Speed: Optimized for performance Fixed: Some hardware acceleration bugs. Confidence score now actually work, yay! Known bugs: Intel QSV hardware acceleration not working, this will requires an updated to the ffmpeg built into Emby. Please use VAAPI for now. Please note: Turning on all settings at once require a large computer to have detections done within a reasonable time so set the settings you need for best results for you and leave the rest. All the options have only been given for users to customize the plugin to work as best as possible with their libraries. Improvements to user-friendliness is next on the todo list. Thank you to @Neminemfor help with testing and bug chasing. Edited January 27 by yocker 1 1
rechigo 367 Posted January 27 Posted January 27 (edited) I am encountering an error when trying to save my settings in the latest version It looks like the input field for the language was accidentally removed. I'm not seeing it anywhere in the HTML Edited January 27 by rechigo
rechigo 367 Posted January 27 Posted January 27 Well I was able to snake my way around that little bug and save my settings... I am very impressed with these new additions! Previously undetected credits in lots of Animes are now detected! Now one thing I would be interested in seeing as an addition would be the ability to open a video player from the chapter marker view and skip to the position the credits were detected in to make it easy to verify detection... is this possible to do?
yocker 1423 Posted January 27 Author Posted January 27 35 minutes ago, rechigo said: I am encountering an error when trying to save my settings in the latest version It looks like the input field for the language was accidentally removed. I'm not seeing it anywhere in the HTML Have fixed it now. Uploading to github as we speak.
yocker 1423 Posted January 27 Author Posted January 27 And it's up now, v1.6.9.0. 5 minutes ago, rechigo said: Now one thing I would be interested in seeing as an addition would be the ability to open a video player from the chapter marker view and skip to the position the credits were detected in to make it easy to verify detection... is this possible to do? I'm working on trying to have a screenshot shown next to the time stamp. Not promising anything though! 1
sydlexius 301 Posted January 27 Posted January 27 (edited) 31 minutes ago, yocker said: And it's up now, v1.6.9.0. I'm working on trying to have a screenshot shown next to the time stamp. Not promising anything though! I was contemplating "borrowing" the UX from SponsorBlock and adapting it to support Emby's existing intro/credit markers, and perhaps add in support for recap/mid-credit scenes, using a similarly highlighted seek bar like how it's done for youtube. It'd be useful purely for manually setting values, and obviously would only work through the web interface. It'd also only store data locally, as previous attempts (ex: Chapter API) had poor uptake on syncing results to a remote server. It's really too bad that there's no standard for storing chapter markers in NFO files! Edited January 27 by sydlexius 2
yocker 1423 Posted January 27 Author Posted January 27 22 minutes ago, sydlexius said: I was contemplating "borrowing" the UX from SponsorBlock and adapting it to support Emby's existing intro/credit markers, and perhaps add in support for recap/mid-credit scenes, using a similarly highlighted seek bar like how it's done for youtube. It'd be useful purely for manually setting values, and obviously would only work through the web interface. It'd also only store data locally, as previous attempts (ex: Chapter API) had poor uptake on syncing results to a remote server. It's really too bad that there's no standard for storing chapter markers in NFO files! Sounds like a good idea if you can get enough people to install and use it. I like it! Sadly i think Emby plus the amount of people actually installing plugins is to small a "sample" to make it work but it's worth a try! 1
rechigo 367 Posted January 27 Posted January 27 (edited) 1 hour ago, yocker said: And it's up now, v1.6.9.0. I'm working on trying to have a screenshot shown next to the time stamp. Not promising anything though! Now if you can't jump to a specific timestamp in a video, could you at least give us a button to open up a video player or the media page so we can play the video ourselves? Just because a single screenshot might not be a perfect indicator Edited January 27 by rechigo
rbjtech 5345 Posted January 27 Posted January 27 6 hours ago, sydlexius said: I was contemplating "borrowing" the UX from SponsorBlock and adapting it to support Emby's existing intro/credit markers, and perhaps add in support for recap/mid-credit scenes, using a similarly highlighted seek bar like how it's done for youtube. It'd be useful purely for manually setting values, and obviously would only work through the web interface. It'd also only store data locally, as previous attempts (ex: Chapter API) had poor uptake on syncing results to a remote server. It's really too bad that there's no standard for storing chapter markers in NFO files! Nice. Remember there is semi support for other chapter types beyond just introstart/end and creditstart. We 'may' be able to get those added as values in the lookup table but I highly doubt we can do this via the API. Using Jellyfins naming as part of their MediaSegments standards would be a good thing for portability as I don't see Emby enhancing this aspect of Emby any time soon. re the NFO - when we did this originally (via the backup plugin), we simply used the chapter type as the key, saved under episodedetails to keep it as simple as possible - so <episodedetails> <introstart>time</introstart> <introend>time</introend> </episodedetails> 1
rechigo 367 Posted January 28 Posted January 28 Im getting a lot of false positives right now... claims of keyword detection even in a timeframe that doesnt have any text on screen. Any pointers?
