rechigo 367 Posted March 14 Posted March 14 I’m running into an issue on the latest version where I’m no longer able to save the tesseract api endpoint when using a docker container name (for example, http://tesseract-ocr:8100). I now get an error message saying that only localhost and local network addresses are allowed.
spk2010 5 Posted March 18 Posted March 18 On 3/13/2026 at 1:22 PM, yocker said: @spk2010@DarWunI finished and added the "fix" to Emby deleting the time stamps. Hopefully this will fix all the problems with Emby doing that until the devs look into the problem. I've been testing the new version since the day you posted it and I still have the same problem, the CreditsStart mark disappears when I click the "Next Episode" button. It's not a problem for me because I restore backups with Cron, but if you need any proof or logs just ask me. 1
yocker 1423 Posted March 18 Author Posted March 18 5 hours ago, spk2010 said: I've been testing the new version since the day you posted it and I still have the same problem, the CreditsStart mark disappears when I click the "Next Episode" button. It's not a problem for me because I restore backups with Cron, but if you need any proof or logs just ask me. New version in the test phase right now. Btw. mind sharing the cron job?
yocker 1423 Posted March 18 Author Posted March 18 (edited) Also just noticed that a metadata refresh makes it so Emby's own intro detection wont run on the series that had the metadata refreshed. The devs might need to look at that one. Edited March 18 by yocker
spk2010 5 Posted March 18 Posted March 18 28 minutes ago, yocker said: Btw. mind sharing the cron job? credits_detector_backup+scan.sh: #!/bin/bash API_KEY="XXXXXXXXXXXXXXXXXX" EMBY_URL="http://localhost:8096" BACKUP_FILE="/home/pi/emby_backup/credits_detector_backup.json" LIBRARY_ID="242" echo "=== RESTAURANT BACKUP ===" if [ ! -f "$BACKUP_FILE" ]; then echo "No hi ha backup, en creo un inicial..." curl -s -X POST "$EMBY_URL/emby/CreditsDetector/ExportCreditsBackup?api_key=$API_KEY" \ -o "$BACKUP_FILE" echo "Backup inicial creat" else jq -Rs '{JsonData: ., OverwriteExisting: false}' "$BACKUP_FILE" > "${BACKUP_FILE}.ready" curl -s -X POST "$EMBY_URL/emby/CreditsDetector/ImportCreditsBackup?api_key=$API_KEY" \ -H "Content-Type: application/json" \ --data @"${BACKUP_FILE}.ready" rm -f "${BACKUP_FILE}.ready" echo "Restauració feta" fi echo echo "=== INICIANT ESCANEIG ===" curl -s -X POST "$EMBY_URL/emby/CreditsDetector/StartDetection?api_key=$API_KEY" \ -H "Content-Type: application/json" \ -d "{\"LibraryId\":\"$LIBRARY_ID\",\"SkipExistingMarkers\":true}" echo URL="$EMBY_URL/emby/CreditsDetector/GetProgress?api_key=$API_KEY" while true; do STATUS=$(curl -s "$URL") RUNNING=$(echo "$STATUS" | jq -r '.IsRunning') DONE=$(echo "$STATUS" | jq '.ProcessedItems') SKIPPED=$(echo "$STATUS" | jq '.SkippedItems') TOTAL=$(echo "$STATUS" | jq '.TotalItems') CURRENT=$(echo "$STATUS" | jq -r '.CurrentItem') echo "Processats: $DONE | Saltats: $SKIPPED | Total: $TOTAL" echo "Actual: $CURRENT" [ "$RUNNING" = "false" ] && break sleep 10 done echo echo "=== ESCANEIG ACABAT ===" echo echo "=== CREANT BACKUP FINAL ===" curl -s -X POST "$EMBY_URL/emby/CreditsDetector/ExportCreditsBackup?api_key=$API_KEY" \ -o "$BACKUP_FILE" echo "Backup guardat a: $BACKUP_FILE" 1
yocker 1423 Posted March 21 Author Posted March 21 Beta if people want to help test. I've been testing and re-testing this for a while now and i seem to have gotten the auto-restore fixed so that time stamps gets restores after Emby removes them. Would love more to test it so it's sure to be bug free. WARNING!!! This is a beta and there might be bugs, as always use at your own risk. EmbyCredits.dll 2 2
yocker 1423 Posted March 22 Author Posted March 22 @Neminemhas been so kind as to help replicate the problem @spk2010has. If no misunderstanding has happened, it look like Embys skip system might have problems sometimes when fast forwarding to many times to fast or resuming a video mid video. It's unrelated to this plugin and does not change the metadata/time stamps of the video and going back and restarting the video usually fixes it. Refreshing metadata, doing rescans and other things can and will in most cases remove the time stamps though, the auto-restore function is made to fix that and is in beta atm. 2
rechigo 367 Posted March 24 Posted March 24 Is mark failed episodes for future skipping known to not work? I just ran the scheduled task once to detect and fail everything, and when I went to run it again it tries detecting all failed credits again
yocker 1423 Posted March 24 Author Posted March 24 1 hour ago, rechigo said: Is mark failed episodes for future skipping known to not work? I just ran the scheduled task once to detect and fail everything, and when I went to run it again it tries detecting all failed credits again With the beta?
yocker 1423 Posted March 24 Author Posted March 24 (edited) New version up (v2.4.0) on yocksers/EmbyCredits Github. Added: Audo-Restore Markers. This will try and detect when Emby have changed the time markers in videos and run a backup restore if the credit markers have been removed. Tracer, this will show videos that have been added and not have detection run on them yet. Changed: Small cosmetic changed. Please note: The Auto-Restore Markers requires automating backup running for up to date backups to use. Also it's not a be all end all solution to Emby removing time markers, it might still fail to notice when it happens sometimes. A real solution would require a fix to Emby it self. It does limit it happening most of the time! Thank you to all who helped!! You know who you are! Special thanks to @Neminemfor being ready to help testing as always!! @GrimReaperI added the functionality you suggested to the editor, thanks for the suggestions! Edited March 24 by yocker 2
rechigo 367 Posted March 24 Posted March 24 9 hours ago, yocker said: With the beta? The stable version right before the one you released today
yocker 1423 Posted March 24 Author Posted March 24 19 minutes ago, rechigo said: The stable version right before the one you released today The new version should have it fixed. 1
rechigo 367 Posted March 24 Posted March 24 (edited) On 3/14/2026 at 12:32 PM, rechigo said: I’m running into an issue on the latest version where I’m no longer able to save the tesseract api endpoint when using a docker container name (for example, http://tesseract-ocr:8100). I now get an error message saying that only localhost and local network addresses are allowed. Anything on this? I see there's a validation function in the source code that's rejecting these URLs even though they are valid. It only allows localhost or ip addresses entered 2 hours ago, yocker said: The new version should have it fixed. Okay I will test it out and report. Appears to be working alright now. Edited March 24 by rechigo
yocker 1423 Posted March 24 Author Posted March 24 1 hour ago, rechigo said: Anything on this? I see there's a validation function in the source code that's rejecting these URLs even though they are valid. It only allows localhost or ip addresses entered Okay I will test it out and report. Appears to be working alright now. Try this version, i removed a couple of blocks made. It should now allow any host name or IP as long as they are local IPs. Note: It will not allow public IPs, made it like that because the Tesseract and PaddleOCR doesn't have any password system that i know of (they are not my containers), so giving access to them from the internet would be a huge security risk and everyone would be able to use them. If you want i can remove any blocks there are, just be mindful of this! EmbyCredits.dll 1
yocker 1423 Posted March 25 Author Posted March 25 New version up (2.4.1) on yocksers/EmbyCredits Github. Changed: Enhanced the Credit Edit with more features. Fixed: Hostnames should now work correctly for connecting to the OCR server. 2
yocker 1423 Posted March 28 Author Posted March 28 New version up (2.4.2) on yocksers/EmbyCredits Github. Changed: 1. Enhancements to the Credit Edit. 1
yocker 1423 Posted March 28 Author Posted March 28 There is now a standalone of the Credit Edit function as per request. It can be found at: yocksers/TimeMarkEdit: Edit chapter time marks in Emby Thank you to @Neminemand @GrimReaperfor testing and suggestions for improvements. 2
sydlexius 301 Posted March 29 Posted March 29 @yockerYou might want to do some testing for "subdirectory" type reverse proxy entries (ex: https://www.domain.com/emby/) as your plugin bombs on loading content in that manner. I have mine setup both as a subdomain (https://emby.domain.com/) and the former, and only now did I observe the issue: 1
yocker 1423 Posted March 29 Author Posted March 29 3 hours ago, sydlexius said: @yockerYou might want to do some testing for "subdirectory" type reverse proxy entries (ex: https://www.domain.com/emby/) as your plugin bombs on loading content in that manner. I have mine setup both as a subdomain (https://emby.domain.com/) and the former, and only now did I observe the issue: Try the one just uploaded to Github. 1
sydlexius 301 Posted March 29 Posted March 29 13 minutes ago, yocker said: Try the one just uploaded to Github. That did the trick! Thanks 1
yocker 1423 Posted March 29 Author Posted March 29 2 hours ago, sydlexius said: That did the trick! Thanks Just a single html request made wrong ruined it so easy fix.
