yocker 1423 Posted December 20, 2025 Posted December 20, 2025 (edited) I decided to release the plugin as everything should be working. Find it at: Edited December 24, 2025 by yocker 3
vincen 73 Posted December 21, 2025 Posted December 21, 2025 Hi Thanks for the share but what's the point as Emby is already doing that by itself no ? Vincèn
yocker 1423 Posted December 21, 2025 Author Posted December 21, 2025 Just now, vincen said: Hi Thanks for the share but what's the point as Emby is already doing that by itself no ? Vincèn Emby does not have end credit detection, it only has intro skip detection.
MediaIntelNUC 36 Posted December 21, 2025 Posted December 21, 2025 Thanx Yocker! A quick question, i have installed the plugin and fixed all options, but have i got it right that the plugin scans mediafiles that i add after it is installed? I didnt see any option regarding scanning of episodes that already is in library.. Thanx again for your work
yocker 1423 Posted December 21, 2025 Author Posted December 21, 2025 32 minutes ago, MediaIntelNUC said: Thanx Yocker! A quick question, i have installed the plugin and fixed all options, but have i got it right that the plugin scans mediafiles that i add after it is installed? I didnt see any option regarding scanning of episodes that already is in library.. Thanx again for your work It should automatically find your TV show library and you can manually start detection on individual tv shows. There is also an option for auto detection and schedule task but I don't recommend it as it is more or less a test plugin for now and might give wildly different and wrong detections.
yocker 1423 Posted December 22, 2025 Author Posted December 22, 2025 (edited) Currently testing a version together with @Neminemthat might actually be something people want to use. It uses OCR to detect text in end credits and so far shows great promise. It will be able to run automatically when new files have been added to Emby like the Emby intro skip detection and/or with scheduled task. Edited December 22, 2025 by yocker 1
yocker 1423 Posted December 22, 2025 Author Posted December 22, 2025 (edited) Here it is ready for testing. Requirements: hertzg/tesseract-server docker container running (haven't tested with other tesseract servers yet). Remember this is a development build. While it works it might still have unexpected faults and errors making it not work with some setups. Recommend using a test server. All i ask is that you please report any problems or ideas for the plugin. EmbyCredits.dll Edited December 22, 2025 by yocker 1
