ManiacKill 0 Posted December 20, 2025 Posted December 20, 2025 Hi everyone, I use Emby's Cast feature. I copied Kodi from a stick with adblink, but now I have the problem that Emby only displays one of the two devices! When I start a movie, it starts on both devices. I have already changed the name in the settings on the device. There must be a link somewhere in Kodi that is causing this problem. Maybe someone knows where? Thanks
TeamB 2440 Posted December 23, 2025 Posted December 23, 2025 its probably the device ID used to ID the client with Emby Server. I think it is in the addon user data directory in kodi for embyCon and if you delete it and restart Kodi the plugin should create a new one.
