Gilgamesh_48 1243 Posted December 19, 2025 Posted December 19, 2025 I am feeling a bit better than usual today so I decided to do a little maintenance. One of the first things I wanted to do was cleanup my Next Up. I realized that my Next up was cluttered and displaying a LOT of shows I was not going watch any time soon. I found that there were nearly 20 such shows and doing them one at a time was going to be time consuming. So I multiselected the shows on Next Up and clicked the resulting three dot menu but the menu displayed did not include a "remove from next up" selection. I was kind of amazed by that and I feel it should have that ability. I decided to post here to advise that the option was missing and to suggest that it might be a good thing to add. I managed to remove all I wanted from Next Up by using multiselect on TV shows and sorting by date last played and the going through the first 20 or 30 shows and marking the ones I do not want in Next Up as totally unwatched. I would have preferred to simply remove them from next up but this worked OK this time. I think it would be best if Emby allowed "remove from next up" on multi-select from next up. But I am really just posting here to advise others what has happened. BTW: Server - Version 4.9.4.1 beta Also I use Windows 10 (Yes I know support has ended but I do not have enough $$$$ to buy a new server and the old one will not support Windows 11) The browser is Chrome. I get no errors at all. 1
Luke 42243 Posted December 19, 2025 Posted December 19, 2025 Hi, yes it's something that can be done. Thanks.
