hspantera 8 Posted December 16, 2025 Posted December 16, 2025 Since the new update to new windows beta server 4.9.4.1 de Dolby vision movies that I new add they are all messed in colors in pink and green. But old Dolby vision movies that I already hd they play well. This only happens on Dolby vision on lg. it works well in all other clients. Any possible problem?
rbjtech 5341 Posted December 16, 2025 Posted December 16, 2025 If they are pink and green, then I'm assuming they are Dolby Vision Profile 5. The others are likely Profile 8.x ? Can you confirm on the Emby mediainfo details ?
hspantera 8 Posted December 16, 2025 Author Posted December 16, 2025 that one shows pink and green this one works fine
hspantera 8 Posted December 16, 2025 Author Posted December 16, 2025 (edited) My versions are always hybrid. They are Dolby vision and hdr compatible. But on the first one Emby don’t analise well the hybrid mode. Maybe that’s the problem of the new update. It análises wrong the new movies I add. Edited December 16, 2025 by hspantera
Solution rbjtech 5341 Posted December 16, 2025 Solution Posted December 16, 2025 (edited) Agreed - the first one listed is not being recognised as DV - so Emby is playing it as HDR (or SDR) - but it has a DV colour range - thus the green/purple. Either convert it to DV8 or obtain another version.. What does MediaInfo (the external software) say about the 1st version ? Edited December 16, 2025 by rbjtech
hspantera 8 Posted December 16, 2025 Author Posted December 16, 2025 Sorry. Everything is ok. The versions that I add weren’t in right format. Problem solved. 1
