fabien_m2002 8 Posted December 16, 2025 Posted December 16, 2025 Hello i own a LG G2 with its remote control. I have color buttons (green, blue, yellow, red). Can i map them to Emby to trigger command? Generally, which buttons work natively with Emby?
Luke 42233 Posted December 16, 2025 Posted December 16, 2025 HI, not currently. What would you like to map them to?
fabien_m2002 8 Posted December 16, 2025 Author Posted December 16, 2025 For example: Blue : Home screen Yellow: toggle full-screen Red: EPG Grid Green: menu/info Also another key for Favorites Thanks
Luke 42233 Posted December 16, 2025 Posted December 16, 2025 Quote Yellow: toggle full-screen Hi, what would this do on a TV?
fabien_m2002 8 Posted December 16, 2025 Author Posted December 16, 2025 4 minutes ago, Luke said: Hi, what would this do on a TV? Swith to full screen media playing. It's the key F: toggle full-screen https://emby.media/support/articles/Keyboard-and-Remote-Support.html
Luke 42233 Posted December 16, 2025 Posted December 16, 2025 Right OK. that doesn't really apply in TV layouts. We'll have to make that more clear.
fabien_m2002 8 Posted December 16, 2025 Author Posted December 16, 2025 Thanks. If possible, i would set a long press on OK: menu/info and Green: Favorites
Luke 42233 Posted December 16, 2025 Posted December 16, 2025 OK yes I think this would be a good thing to add then. 1
fabien_m2002 8 Posted February 5 Author Posted February 5 Hello is this feature on the roadmap? Thanks
Luke 42233 Posted February 11 Posted February 11 On 2/5/2026 at 9:07 AM, fabien_m2002 said: Hello is this feature on the roadmap? Thanks Hi, long press yes.
