bobbee001 4 Posted December 15, 2025 Posted December 15, 2025 I noticed that I have lost the home screen, i.e current movies being watched. Started server, wouldn't accept my known passwrod. Selected lost password, read txt file, went to web and entered token. Msg that the password was blanked out, ligin without a password. When try it states token expired, only was a minute or two. HELP Note I have files (2 weeks old) copied from \users\bob\AppData\Roaming\emby-server\programdata\data\ Would any of them enable the logon ?
Luke 42288 Posted December 16, 2025 Posted December 16, 2025 Quote When try it states token expired, only was a minute or two. Hi, where exactly does it say that?
bobbee001 4 Posted December 16, 2025 Author Posted December 16, 2025 I have moved on as the problem seem larger. (error was on win11. Pleae refer attemotedvideo access and recieved SQL errors Home Emby Server General/Windows can't run emby setup To fix all my issues, tried uninstalling emry and reinstalling on windows 11. stops at 50%
HjanecksD03 2 Posted December 16, 2025 Posted December 16, 2025 That clears things up. Password reset issues can be really confusing, especially with cached links or mail delays.
