Too many problems with my LG and Philips TVs.
TechMinerUK
14 hours ago, Luke said:
OK then maybe try refreshing metadata on an existing title, and then see if you can play after that.
Just on this, refreshing the metadata doesn't appear to make it work in my instance, neither does moving the file though which is odd
Try changing the name; I know it sounds silly, but it works for now. As for updating the metadata, I think I already did that, but since it's noted, I'll check it on the 24th and 25th.
Which LG TV isn't working for you? I'm having problems with two OLEDs, one from March, I think, and the other has a June/July manufacturing date, both from 2025...
I get the same error with a Philips Ambilight, but it's 2 or 3 years old, compared to the LGs, which are all 4K TVs. The Philips, which I think costs about the same, is terrible.
  • Thanks 1
TechMinerUK
I'll have a go at changing the file name, for me ironically it's one that got bought last year, it's one of the OLED 4K bezeless ones, the others which are working are from 2023, 2021 and 2019 which are fine
