sign in page does not load for emby connect
Go to solution Solved by Neminem,
When I browse to https://app.emby.media/ and click sign in, all that happens is I get redirected to blank page with the emby logo. This happens across multiple devices. It does not matter if I am on my wifi or if I am using 5g on my phone. I have tried clearing cache, history, new browser, changing the dns server. Going directly to the server works both as a ip address and as a fdqn.
thank you. I see in the quickstart it needed to be http. My browser was making it https instead of http. Once i was use http everything loaded properly and worked.
  • Like 1
What Sign in button are you referring to?
I am experiencing the same thing for many hours now.
Non-SSL version of app.emby.media does load properly on All of my devices while the https version only keeps showing me the emby logo and not the emby connect login fields/window.
my remote server allows / uses https and previously it always worked when I (manually & explicitly) chose to use the https / encrypted login website of app.emby.media
also, isn’t it inherently insecure to login through the non-SSL version of the site? (Even if you’d use a vpn)
Running into this as well. app.emby.media loads fine with http, but not https. I can see this in the developer console which is probably the cause.
HI, thanks, we'll take a look.
