Noodlewasser 68 Posted December 13, 2025 Posted December 13, 2025 Hi, I just discovered the newish setting "Max transcoding resolution" and I am confused about how it is supposed to work. Does the limit apply to the source or the target resolution? In any case, in my tests the setting appears to be completely ignored. If I set the limit to 1080p the server still transcodes 4K->1080p, but also 4K->4K (confirmed via dashboard and playback stats). Did I misunderstand the setting?
TMCsw 259 Posted December 13, 2025 Posted December 13, 2025 13 hours ago, Noodlewasser said: 4K->4K That would be: Direct Play (right?) = no transcoding. That setting is only in effect when a transcode is triggered. When transcoding is triggered, the output will be limited to 1080p in your case.
Noodlewasser 68 Posted December 13, 2025 Author Posted December 13, 2025 48 minutes ago, TMCsw said: That would be: Direct Play (right?) = no transcoding. No, it's transcoding from a higher to a lower bitrate, both in 4K.
TMCsw 259 Posted December 14, 2025 Posted December 14, 2025 2 hours ago, Noodlewasser said: it's transcoding from a higher to a lower bitrate If that's the case, then it sounds like a bug. The devs will need to see logs from when this happens (embyserver* ffmpeg-transcode*) and maybe some screenshots... https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/
yocker 1414 Posted December 14, 2025 Posted December 14, 2025 17 hours ago, Noodlewasser said: Hi, I just discovered the newish setting "Max transcoding resolution" and I am confused about how it is supposed to work. Does the limit apply to the source or the target resolution? In any case, in my tests the setting appears to be completely ignored. If I set the limit to 1080p the server still transcodes 4K->1080p, but also 4K->4K (confirmed via dashboard and playback stats). Did I misunderstand the setting? It's a limit on the resolution of the transcoding done on the server. So set it at 1080p and any transcode will be at a maximum of 1080p. As you can see here it is being limited to 10 mbps even though i set it to 40 in the player.
Luke 42242 Posted December 14, 2025 Posted December 14, 2025 HI can you please show us what exactly you discovered? Thanks.
