WBoweIII 7 Posted December 9, 2025 Posted December 9, 2025 I intend to install Emby on a PC that lives on my boat. I don't have great connectivity at the Marina so I will have to store Movies/Shows on an external drive and bring them back and fourth occasionally to add/subtract. Just curious if there is anything I need to look out for? I am already storing the artwork and nfo's with the movie. Is removing this storage going to break Emby in any way or do I just need to plug it back in and scan the library when I get back to the boat? Thanks - any advice would be appreciated
Solution Luke 42287 Posted December 9, 2025 Solution Posted December 9, 2025 Hi, you may just want to remove the schedule for the scan library scheduled task and run it manually. Other than that I think you will be fine.
