justinrh 266 Posted December 9, 2025 Posted December 9, 2025 What is good practice when converting video with respect to bit-depth? Is it best to match or does increasing it do any good? I usually go from MPEG to AVC or HEVC. Note: I just did a test with HandBrake where my source was 8-bit, then converted to HEVC with 10-bit, 12-bit, and 8-bit. The 10-bit was the largest file size and the others about 100MB smaller.
Luke 42233 Posted December 9, 2025 Posted December 9, 2025 HI, there is no reason to increase it when converting. I would suggest matching to preserve data. 1
Suliamu 41 Posted December 11, 2025 Posted December 11, 2025 x265/HEVC behaves differently than x264/AVC and there is a lot of subjectivity involved in assessing the results, but here in this article the author argues strongly for converting 8bit to 10bit HEVC, at least for Anime quote: Quote To keep things short and not get into technical details: use the 10-bit encoder (Main 10 profile). 10-bit produces slightly smaller files while preventing banding from 8-bit compressions (this isn’t a joke, quantization and linear algebra is a mysterious thing). Why not just use 12-bit then you say? Well, to put simply: moving form 8 to 10 bit increases color gradient available from 256 to 1024 to eliminate banding, but going to 4048 in 12-bit really isn’t noticeable. In fact, it is much less supported, and from my tests back in 2018 the 12-bit encoder is actually worse than the 10-bit encoder at high crf likely due to less resources put into developing it. https://kokomins.wordpress.com/2019/10/10/anime-encoding-guide-for-x265-and-why-to-never-use-flac/#which-x265-encoder-8-bit-10-bit-or-12-bit 1
justinrh 266 Posted December 11, 2025 Author Posted December 11, 2025 Thanks for that info. That makes sense with why HB defaults to 10-bit for HEVC. Didn't expect 10-bit to create a smaller file ...
