knoll126 11 Posted December 7, 2025 Posted December 7, 2025 Hi, I have channel tags that I am restricting per user via parental controls. Those users can still see those channel tags when browsing the TV Guide (at the top) and by select Tags that I can see. Now when they select those channel tags they get no results. But I don't even want them to be able to see the channel tags. Is this possible? Thanks!
knoll126 11 Posted December 13, 2025 Author Posted December 13, 2025 For anyone that might fine this useful in the future. I was using "Allow items with these tags" as I thought that was easier to manage, as an admin you usually give access. When checking on those users I then noticed none of them had access to the DVR recordings. It appears that DVR recordings have some hidden tags on them. So I then changed the tag restriction mode to "Block items with these tags". The DVR recordings were then made accessible to the user(s) and the tags that were restricted no longer appeared on the TV Guide. 1
