emby-newb 2 Posted December 31, 2025 Author Posted December 31, 2025 10 minutes ago, Happy2Play said: Yes so next we would need to see the embedded info of the files ffprobe -i "pathtofile" You should see the command in your server log when you Refresh the Metadata also after you change this option. This?
emby-newb 2 Posted December 31, 2025 Author Posted December 31, 2025 So wanting to shutdown the emby server, move the files out of the library to somewhere else in the nas, re-edit and do all changes, then move them back after a while for the cached data to go away, and restart. See what that does. Opinions?
Luke 42287 Posted December 31, 2025 Posted December 31, 2025 2 hours ago, emby-newb said: Here's mine. I'll uncheck it and rescan Yea this probably explains why you got titles with video info in them.
Luke 42287 Posted December 31, 2025 Posted December 31, 2025 1 hour ago, emby-newb said: So wanting to shutdown the emby server, move the files out of the library to somewhere else in the nas, re-edit and do all changes, then move them back after a while for the cached data to go away, and restart. See what that does. Opinions? HI, yes you could certainly do that. Please let us know what happens.
Happy2Play 9814 Posted January 1 Posted January 1 21 hours ago, emby-newb said: This? Yes you can copy and paste everything after "Execute: " into terminal/commandline to see the embedded info.
emby-newb 2 Posted January 25 Author Posted January 25 (edited) Hey everyone sorry for the long delay. I uploaded the dump of the log file instead. I uploaded: "The Pink Panther Cartoon Collection" (https://www.imdb.com/title/tt12768740/), and manually edited it since it was not working. Well after emby was updated, it wiped everything which is the topic of this post. Also uploaded "The Flinstones" (https://www.imdb.com/title/tt0053502/) and "The Jetsons" (https://www.imdb.com/title/tt0055683/) They're all broken and manual updates to metadata get rewritten. Several other TV series like: tiny toons adventures (https://www.imdb.com/title/tt0098929/) Fallout season 2 (https://www.imdb.com/title/tt12637874/) are also broken as shown in previous posts and again in the included attachments. Hopefully you guys can figure out what the logs say because Im not sure what is happening. Appreciate you all. embyserver.txt Edited January 25 by emby-newb
emby-newb 2 Posted January 25 Author Posted January 25 (edited) UPDATE: several files are failing to play on emby via shieldTV. See below snapshot of error and updated logfle. Said videos play just fine in other apps and devices i.e. VLC on the same shieldTV embyserver2.txt Edited January 25 by emby-newb
Happy2Play 9814 Posted January 26 Posted January 26 6 hours ago, emby-newb said: Hey everyone sorry for the long delay. I uploaded the dump of the log file instead. I uploaded: "The Pink Panther Cartoon Collection" (https://www.imdb.com/title/tt12768740/), and manually edited it since it was not working. Well after emby was updated, it wiped everything which is the topic of this post. Also uploaded "The Flinstones" (https://www.imdb.com/title/tt0053502/) and "The Jetsons" (https://www.imdb.com/title/tt0055683/) They're all broken and manual updates to metadata get rewritten. Several other TV series like: tiny toons adventures (https://www.imdb.com/title/tt0098929/) Fallout season 2 (https://www.imdb.com/title/tt12637874/) are also broken as shown in previous posts and again in the included attachments. Hopefully you guys can figure out what the logs say because Im not sure what is happening. Appreciate you all. embyserver.txt 32.07 kB · 0 downloads No info comes directly from IMDB so what they have is not always what TVDB or TMDB have when it comes to cartoons. What is are your enable metadata providers for this library and their order? Only one potentially exact will be OMDB but will not have as much info per item. But if you are manually editing files you will need to ensure you LOCK the metadata as any refresh of the Show will/could update wrong data from enabled providers. As for the client issue first question would be does it have issues in the Web Client?
Luke 42287 Posted January 26 Posted January 26 6 hours ago, emby-newb said: UPDATE: several files are failing to play on emby via shieldTV. See below snapshot of error and updated logfle. Said videos play just fine in other apps and devices i.e. VLC on the same shieldTV embyserver2.txt 542.76 kB · 0 downloads Did you see this in the log? 15:50:20.496 /mnt/Main_Pool/Video_Dataset/TV SERIES/Tiny Toons/S03E05 - Flea for Your Life.mp4: No such file or directory 15:50:20.496 EXIT
