Shahram7 0 Posted December 5, 2025 Posted December 5, 2025 Hi Luke, hope you're doing well. I've just bought a Hisense M2 Pro projector. I thought I would be fine using the web version. You can add the bookmark to your homepage, but there are still major issues: you have to navigate with a pointer, and you can't move through the menus with the up and down keys on your remote. Many menus are not fully visible because you can't scroll when a pop-up menu is open. Another big issue I just discovered: the Vidaa OS browser can't handle any SRT subtitles. Is there still any hope for getting an Emby app for Vidaa? Regards
Luke 42237 Posted December 5, 2025 Posted December 5, 2025 7 minutes ago, Shahram7 said: Another big issue I just discovered: the Vidaa OS browser can't handle any SRT subtitles. Hi, no browser handles srt directly but the server converts them on the fly to something that is compatible.
Shahram7 0 Posted December 5, 2025 Author Posted December 5, 2025 1 hour ago, Luke said: Hi, no browser handles srt directly but the server converts them on the fly to something that is compatible. Do you mean it could be fixed on the Emby server side? It's a good news
Luke 42237 Posted December 6, 2025 Posted December 6, 2025 @Shahram7 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Shahram7 0 Posted December 6, 2025 Author Posted December 6, 2025 Hi Luke, thank you for creating a new topic and for moving my post. I've turned on debug mode in the logging settings, and here are the logs. Best regards, Shahram embyserver (1).txt
Shahram7 0 Posted December 15, 2025 Author Posted December 15, 2025 Hi Luke, I just wanted to ask whether I have provided all the necessary information for you to identify the cause of the issue. Do you need anything else from my side? Best regards, Shahram
