falad0x 2 Posted December 5, 2025 Posted December 5, 2025 Hello, I’ve recently had an issue with Emby Server version 4.9.1.90 (DSM 7.3) and the Emby client 2.2.45 (iOS). On some music folders, playback doesn’t work properly — the display is broken (see screenshot). These are just basic .mp3 files.
Luke 42239 Posted December 6, 2025 Posted December 6, 2025 HI, so you're saying the bottom icons are missing?
falad0x 2 Posted December 6, 2025 Author Posted December 6, 2025 I’m forced to go through the lock screen or the control center to change the music.
falad0x 2 Posted December 6, 2025 Author Posted December 6, 2025 If it helps, I also have the problem on the ‘web’ section. I’m using Chrome version 142.0.7444.176.
Neminem 1623 Posted December 9, 2025 Posted December 9, 2025 (edited) On 12/6/2025 at 9:32 PM, falad0x said: If it helps, I also have the problem on the ‘web’ section. I’m using Chrome version 142.0.7444.176. Have you tried more than just playing 1 file ? There is only 1 file in your queue ! edit. If only 1 file in queue then how can you skip to next or previous? Edited December 9, 2025 by Neminem 1
