SouthernMan 0 Posted December 2, 2025 Posted December 2, 2025 Hello everyone. Can this top menu be hidden like jellyfin allows me to do? My elderly parents keep getting stuck on it. I need this to be as basic as possible for them where they click the library they want and it takes them directly to the movie grid without any other ability to stuck on a menu somewhere and have to call me. I’m enclosing screenshots of Roku and Android /Nvidia Shiled. thanks for the help.
ebr 16332 Posted December 2, 2025 Posted December 2, 2025 Hi. There is currently no way to do that. Please lend your support to:
speechles 2062 Posted December 2, 2025 Posted December 2, 2025 (edited) You can have them set a default tab in the Roku app they use. It will be remembered that way. This will be their landing tab. Then the next time they enter that library it will start at the default. It will show their landing tab. They will still see all the tabs. But at least this way it lands them on the right one when they enter each library. Note: Press * (star) on the Roku remote when inside the library you wish to change the landing tab. Edited December 2, 2025 by speechles 1
