Nzzer0 7 Posted December 2, 2025 Posted December 2, 2025 (edited) As a parent, I always need to go in and choose "view parental ratings" in every list view. Please can we have it as a default globally as this is very fiddly with so many libraries. Also, you cant view parental ratings in lists at all on the android TV app. Also you cant do it in collection view (on any platform) so please can we have parental ratings visible when looking at a collection? Edited December 2, 2025 by Nzzer0
Luke 42243 Posted February 4 Posted February 4 Hi, yes we plan to add more global control over this in future updates. Thanks for the feedback.
ebr 16335 Posted February 4 Posted February 4 On 12/2/2025 at 2:31 AM, Nzzer0 said: Also, you cant view parental ratings in lists at all on the android TV app Hi. Specifically, which lists?
Nzzer0 7 Posted March 1 Author Posted March 1 On 05/02/2026 at 11:27, ebr said: Hi. Specifically, which lists? collections, library folder views (whci is what i use all the time) , etc by the way, while we're here I just want to also ask that you can set the default view per library (eg folder view) bceuase on the TV it always goes to "everything mashed together view" (first tab) then you have to move across whcih is a real pain, and in fact its a deal breaker for my kids so they dont like using emby, its too fiddly.
Luke 42243 Posted March 1 Posted March 1 7 minutes ago, Nzzer0 said: collections, library folder views (whci is what i use all the time) , etc by the way, while we're here I just want to also ask that you can set the default view per library (eg folder view) bceuase on the TV it always goes to "everything mashed together view" (first tab) then you have to move across whcih is a real pain, and in fact its a deal breaker for my kids so they dont like using emby, its too fiddly. Hi, have you explored your Emby user Home Screen settings? You can set the default tab there.
ebr 16335 Posted March 1 Posted March 1 Can you show a screenshot? Ratings are shown by default in the Android TV app - unless you are looking at a folder which doesn't have a rating. Also, in the TV app there is a cog icon top right of each library view. Click it and set your default tab.
Nzzer0 7 Posted March 26 Author Posted March 26 Thanks. Yes the TV ratings are shown by default in some views but they dont show up in some eg I think maybe collections? Collections are weird because you cant sort and filter them or have parental ratings show, at least in the web browser, and maybe TV as well as far as I remembver. Its confusing since the platforms are very different and also change over time. But you are right that the TV app shows parental ratings by default now, which is great ... Wish it did in the browser but yeah it seems to have improved i think? (I know you can change it in the TV app but setting that each time using a remote is not gonna happen). 1
