Mendocinotim 22 Posted November 30, 2025 Posted November 30, 2025 I have noticed an issue when using the Versions drop-down to select a movie or tv show episode version. I have been using Versions in an unusual way. I say unusual, because I understand it is intended for when you might have one version that is 720 and another version that is 4k; or when you have a 3D version and a 2D version, etc. In my case however, I have an older Drobo RAID that is starting to fail, in that it is no longer alowing me to write to it, and is now read-only. Thus, I cannot delete a movie or tv episode from that RAID volume, that I had not initially watched to make sure it was okay. Only later, when I finally get around to watching it, I might then notice that it is sub-par, poorly encoded, or low (unwatchable) resolution. My (temporary) solution - until I can afford to replace the Drobo RAID with a better and more modern RAID unit - is that I set up a second 10TB drive, on which I can add and work with new content, which I told Emby to also look at for my movies and TV stuff. The versions issue.. When I add a better copy of a movie or show episode, and then use the Versions drop-down to select that better copy - which BTW: I tag all better copies by adding ".BetterCopy" to the actual file name, right before the file extension. For example: "My Movie (2015).BetterCopy.m4v". This way I can be sure to identify the better copy because it's shown in the drop down. But when I use that drop down to select a version, and it does not properly switch to the desired one, that is a problem. And I wonder if there is something you can do to fix this issue - which sometimes works, and other times does not? Thank you (in advance) for your consideration.
Luke 42237 Posted December 1, 2025 Posted December 1, 2025 HI there, can you please provide a specific example? How to Report a Problem Thanks !
