GrimEvil 73 Posted November 29, 2025 Posted November 29, 2025 I am using the default Android App on my Shield TV, but do not see the below options displayed(Channel Tabs) On the web they works as per the above. on my phone they show on both Android and iPhone devices in landscape and portrait mode. On the shield they are only view able from the left setting tab?
GrimReaper 4896 Posted November 29, 2025 Posted November 29, 2025 3 hours ago, GrimEvil said: I am using the default Android App on my Shield TV By "default" do you mean AndroidTV app? If so, you can download and install Standard/Universal Android app from the store (search for "Emb") which should provide you same layout as on your phone.
Luke 42239 Posted November 29, 2025 Posted November 29, 2025 HI, what version number of the app are you running?
GrimEvil 73 Posted December 1, 2025 Author Posted December 1, 2025 (edited) To confirm I am using the standard android app 3.5.16 on my shield tv, I have also uninstalled and reinstalled it directly from the store and it is still the same issue as below. Edited December 1, 2025 by GrimEvil
Luke 42239 Posted December 1, 2025 Posted December 1, 2025 Ok yea we haven’t added that to tv layouts yet. We are looking at how best to do that. Thanks.
