JanS48 2 Posted November 29, 2025 Posted November 29, 2025 Emby ceases playing an IPTV stream after a few minutes. Both my Emby Windows and Emby Linux have this behavior: After playing an IPTV stream for several minutes it will just cease and return to the menu with no warning or error message - you would think it would at least throw an error message of some kind. I've tried playing both with/without hardware accel., it's slightly better with it turned off. Platforms: Debian13 Linux - native install - hdw: Older Phenom X6 w 16g of ram, SSD hard drives with cache on it's own SSD. Windows 11 Pro, i5 processor 16g of ram, Emby is running on a 500g nvme drive (very fast). VPN - I try to always use a VPN, Windows = IPVanish, Linux = Surfshark Even with no VPN on I still get this behavior - happens most on CNN. If nothing else add an error msg. to the screen IO when this happens.
Luke 42239 Posted November 29, 2025 Posted November 29, 2025 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
