rbjtech 5341 Posted November 28, 2025 Posted November 28, 2025 So I have been happily using the Nvidia Shield wired Ethernet running at 1Gb for the past 5+ years, same fixed wiring etc. However yesterday, half way though watching a movie - I get a permanent disconnection. I check everything obvious, cabling, switch etc. The Ubiquiti switch has blocked the port I'm using, suggesting STP - err... ok. So I reset the port (and eventually the switch), STP resets but no joy connecting. I try a different port - no joy. I try a laptop on the port/shield connection - zero issues. I conclude the Shield Ethernet port appears to be dead. Wireless works fine. As a last resort I then set the port to manual negotiation (1000 FX) and bingo - port/Shield springs into life with seemingly zero issues. All very odd - how can something working for the last X years suddenly change like that - it's not a f/w issue on the shield as that has been blocked for years as I'm on (and want to stay on) SE8. Anyway - posting this as a possible resolution for a disconnected Nvidia Shield Pro.
vincen 72 Posted November 28, 2025 Posted November 28, 2025 Hi I would stay an Unifi update as they are quite good at pushing updates that mess things sometimes Is your Shield being connected both at Wifi and Ethernet in same time ? I got that issue with some devices on Unifi network in past. Vincèn 1
Neminem 1619 Posted November 28, 2025 Posted November 28, 2025 It sound like auto negotiation is failing. I have seen that on some old equipment in the past, specialty if connected to a POE switch. Not sure if that's the case here. 1
rbjtech 5341 Posted December 1, 2025 Author Posted December 1, 2025 (edited) On 28/11/2025 at 16:18, vincen said: Hi I would stay an Unifi update as they are quite good at pushing updates that mess things sometimes Is your Shield being connected both at Wifi and Ethernet in same time ? I got that issue with some devices on Unifi network in past. Vincèn Possibly - but very odd why it suddenly failed. It's been on Ethernet/Auto-Neg/DHCP reserved for years. If I plug anotehr device into the same wall port, then it all works perfectly again - so I *think* it's the Shield itself no longer Auto-Neg, but why I have no idea. On 28/11/2025 at 17:50, Neminem said: It sound like auto negotiation is failing. I have seen that on some old equipment in the past, specialty if connected to a POE switch. Not sure if that's the case here. I guess it's possible some components may have degraded as part of the Auto-Neg process due to age Very odd however as the Auto-Neg happens at the OSI Data Link layer - and this was plugged in and working when it decided to 'quit' .. I hope it holds out under manual forcing 1000FX lol .. Edited December 1, 2025 by rbjtech 1
vincen 72 Posted December 1, 2025 Posted December 1, 2025 19 minutes ago, rbjtech said: I guess it's possible some components may have degraded as part of the Auto-Neg process due to age I know it's a quite boring process but I would try a full factory reset of the device and see what happens ! If you plug it on a completely different switch (different manufacturer if possible, how does it go ?
rbjtech 5341 Posted December 1, 2025 Author Posted December 1, 2025 15 minutes ago, vincen said: I know it's a quite boring process but I would try a full factory reset of the device and see what happens ! If you plug it on a completely different switch (different manufacturer if possible, how does it go ? It's working as a manual speed, but it if quits completely then I'll try a factory reset 1 1
justinrh 266 Posted December 1, 2025 Posted December 1, 2025 I would think it to be a hardware issue. Try a new cable? Clean the Ethernet ports?
