tesla1886 3 Posted November 27, 2025 Posted November 27, 2025 I have (I think) all 6 Superman movies. Superman1, 2, 3, 4 Superman Returns and Superman (2025 version). All but the first one is in my library. I have reload web browser page, restarted Emby, restarted the computer, removed and recreated the library. No matter What I have tried I am unable to get Superman 1 in the list. I also have the original The Karate Kid, however instead of having the media data for the 1984 version, it has the media data for the 2010 version.The 1984 version is the only one I currently have. I have tried to replace the IDs for IMDB, TVDB and Movie DB but cannot get the correct media data to be applied. Anybody have any idea how I can resolve these issues?
darkassassin07 674 Posted November 27, 2025 Posted November 27, 2025 (edited) The best way I've found to ensure perfect matching every time is to include IDs from either imdb of TheMovieDB in the folder name. Depending on which Superman you're talking about that'd be: /movies/Superman (1978) [tmdbid=1924]/Superman (1978).mkv Or /movies/Superman (1941) [tmdbid=95414]/Superman (1941).mkv /movies/The Karate Kid (1984) [tmdbid=1885]/The Karate Kid (1984).mkv If you use tools like Radarr, you can change the 'Movie folder format' to include these automatically when importing media: {Movie Title} ({Release Year}) [tmdbid={TmdbId}] Edited November 27, 2025 by darkassassin07 2
Solution tesla1886 3 Posted November 28, 2025 Author Solution Posted November 28, 2025 4 hours ago, darkassassin07 said: The best way I've found to ensure perfect matching every time is to include IDs from either imdb of TheMovieDB in the folder name. Depending on which Superman you're talking about that'd be: /movies/Superman (1978) [tmdbid=1924]/Superman (1978).mkv Or /movies/Superman (1941) [tmdbid=95414]/Superman (1941).mkv /movies/The Karate Kid (1984) [tmdbid=1885]/The Karate Kid (1984).mkv If you use tools like Radarr, you can change the 'Movie folder format' to include these automatically when importing media: {Movie Title} ({Release Year}) [tmdbid={TmdbId}] Awesome that worked! Thank You 1 1
tesla1886 3 Posted December 8, 2025 Author Posted December 8, 2025 This appears to be an issue with everything I try to play. Is there a way to turn off sub titles by default? I have gone into settings and turned sub titles off, but that has only worked for once thus far. While playing others even if the subtitles are off I have to turn them on then turn them off for the file to play. How do I get a response from a developer or is there a way I can contact them
tesla1886 3 Posted December 8, 2025 Author Posted December 8, 2025 This appears to be an issue with everything I try to play. Is there a way to turn off sub titles by default? I have gone into settings and turned sub titles off, but that has only worked for once thus far. While playing others even if the subtitles are off I have to turn them on then turn them off for the file to play. When play files with VLC with subtitles enable they play just fine. If it matters I used DVDFab to rip my DVDs which has a feature to add subtitles when available. How do I get a response from a developer or is there a way I can contact them
pwhodges 2039 Posted December 8, 2025 Posted December 8, 2025 This forum is how you contact the Emby developers. Including server logs for the time when the behaviour you describe happened helps. Are the subtitles marked as "forced" (look at the media details at the bottom of the item's description page)? When subtitle settings are overridden manually, Emby remembers this for that item - possibly (I'm not sure) for other unplayed items in the same series> - You can clear the remembered selections in the user app data. Does that help? Paul
Luke 42288 Posted December 8, 2025 Posted December 8, 2025 15 hours ago, tesla1886 said: This appears to be an issue with everything I try to play. Is there a way to turn off sub titles by default? I have gone into settings and turned sub titles off, but that has only worked for once thus far. While playing others even if the subtitles are off I have to turn them on then turn them off for the file to play. How do I get a response from a developer or is there a way I can contact them Hi there, have you explored your emby user subtitle preferences by clicking the user icon in the upper right? How are those options configured?
brothom 211 Posted December 9, 2025 Posted December 9, 2025 (edited) On 28/11/2025 at 04:03, tesla1886 said: Awesome that worked! Thank You Personally I would suggest to NOT use the id's the your media file unless it's an absolute necessity. Movies should 99% of the time be matched if you follow the suggest naming convention of: Title (year) - edition So: Superman (1978)/Superman (1978).mkv Superman 2 (1980)/Superman 2 (1980).mkv Superman 3 (1983)/Superman 3 (1983).mkv ... Superman (2025)/Superman (2025).mkv Be sure to always include the years. That makes managing the files easier for yourself and Emby. On 08/12/2025 at 05:13, tesla1886 said: This appears to be an issue with everything I try to play. Is there a way to turn off sub titles by default? I have gone into settings and turned sub titles off, but that has only worked for once thus far. While playing others even if the subtitles are off I have to turn them on then turn them off for the file to play. When play files with VLC with subtitles enable they play just fine. If it matters I used DVDFab to rip my DVDs which has a feature to add subtitles when available. You can turn off the subtitles for each user individually: 1. Emby Server -> Users -> select a user 2. Click "Edit this user's profile, image and personal preferences" 3. Go to Subtitles 4. Set Subtitle mode to "No subtitles" Edited December 9, 2025 by brothom
