Solution sa2000 697 Posted November 28, 2025 Solution Posted November 28, 2025 (edited) 5 minutes ago, Macca500 said: Ok. I did this and it only showed a space between them. Do I delete the space? How do I then fix it? Your earlier screenshot shows you have the show folder twice - one with the invalid characters. The one with the space is ok. The one with the special characters is not. Get rid of the bad duplicates leaving only one and make sure the files themselves do not have invalid characters in their names Edited November 28, 2025 by sa2000 1
sa2000 697 Posted November 28, 2025 Posted November 28, 2025 once you have done that. restart the server and do a library scan and see what happens. upload the log if there are still issues
Macca500 6 Posted November 29, 2025 Author Posted November 29, 2025 10 hours ago, sa2000 said: once you have done that. restart the server and do a library scan and see what happens. upload the log if there are still issues It looks like this has fixed the issue and the error was in relation to that bad file name which was causing it to not scan that drive. It is in the process of scanning the library now. Thank you so much!! 1 2
sa2000 697 Posted November 29, 2025 Posted November 29, 2025 1 hour ago, Macca500 said: It looks like this has fixed the issue and the error was in relation to that bad file name which was causing it to not scan that drive. Great. Thanks
