Hispanico957 23 Posted November 24, 2025 Posted November 24, 2025 I'm trying to download a movie to my tablet via Wi-Fi... I click download (1.5 Mbps) but I don't see anything in the downloads. On the server, I see the file I selected for download being converted, but I don't see any progress. If I go to my tablet, I don't see anything in the downloads. Thanks for your help. Hispa
Luke 42175 Posted November 24, 2025 Posted November 24, 2025 Hi, it looks like it has to be converted, so this happens first before the download.
Hispanico957 23 Posted November 24, 2025 Author Posted November 24, 2025 14 minutes ago, Luke said: Hi, it looks like it has to be converted, so this happens first before the download. Ah but conversion necessary or not? And if not necessary where i can enable/disable it ? Thank Hispa
Luke 42175 Posted November 24, 2025 Posted November 24, 2025 Just now, Hispanico957 said: Ah but conversion necessary or not? And if not necessary where i can enable/disable it ? Thank Hispa It will only convert if necessary. 1
Hispanico957 23 Posted November 24, 2025 Author Posted November 24, 2025 (edited) Ok i follow you but now on server i have this "ready for download"... but remain in this stage. On client (tablet) nothing download After the conversion, shouldn't the download start automatically? Hispa Edited November 24, 2025 by Hispanico957
sa2000 689 Posted November 25, 2025 Posted November 25, 2025 12 hours ago, Hispanico957 said: After the conversion, shouldn't the download start automatically? Yes - the emby app will be checking for any ready downloads and would start a download if the file is not already in the downloads on the device Relaunch the app and connect to the server through wifi and wait - it should start to download
Hispanico957 23 Posted November 25, 2025 Author Posted November 25, 2025 Not start... In severa the file is ready and in the client emby on pad Apple nothing happened.. Hispa
sa2000 689 Posted November 25, 2025 Posted November 25, 2025 1 minute ago, Hispanico957 said: Not start... In severa the file is ready and in the client emby on pad Apple nothing happened.. OK. Lets get some logs - for a new download So suggest first enabling debug logging on the server - see Log Files Then relaunch Emby Server Then on the iPad exit the Emby for iOS app and relaunch it Connect the Emby for iOS app to the emby server with an account that has downloads allowed through wifi Select a media file on the server that has not been downloaded before and select download Monitor status of the download on the emby server dashboard - it should go to converting and then ready for download and then downloading If you are sure this does not complete or start downloading whilst the app is available and connected through wifi and running and open on the iPad then download the emby server log file and attach here together with details of what was being downloaded and when and how long you waited for it to complete.
Hispanico957 23 Posted November 25, 2025 Author Posted November 25, 2025 Thanks, I'm attaching the log, but I think I've solved the problem, at least for now. I was downloading multiple files from my iPad, but none of them would download, even if they were converted. I tried downloading just one at a time, and this time, no problem... Check and let me know Thank Hispa ffmpeg-transcode-2851fa92-57fb-4bc2-b664-536a59b910c1_1.txt ffmpeg-transcode-1bc808b9-26f6-4e56-8e63-43f6a05ae390_1.txt ffmpeg-transcode-b1e06c93-614a-4feb-8fdf-fffa889646ad_1.txt ffmpeg-transcode-273a6418-4181-4f30-9fe4-c63153ff9bd0_1.txt embyserver (6).txt
Luke 42175 Posted November 26, 2025 Posted November 26, 2025 Ok we’ll take a look at that scenario. Thanks.
sa2000 689 Posted November 26, 2025 Posted November 26, 2025 (edited) 15 hours ago, Hispanico957 said: I was downloading multiple files from my iPad, but none of them would download, even if they were converted. I tried downloading just one at a time, and this time, no problem... Do the logs you provided cover the time when the problema arose ? when downloading multiple files to the iPad and none of them would download ? Let me know which files because I do not see a problem in the log. Tell me what did not download I can see the following Vicious (2025).mkv Requested 15:17:36, Ready at 15:17:37, Download started at 15:17:40, completed at 15:19:10 Welcome to Derry - S01E05 - 29 Neibolt Street.mkv Requested 15:19:26, Ready at 15:27:19, Download started at 15:27:23, completed at 15:29:53 Bring Her Back - Torna da me (2025) 4K.mkv Requested 15:30:12, Ready at 15:37:15, Download started at 15:37:17, completed at 15:39:35 L'Illusione Perfetta (2025).avi Requested 15:39:46, Ready at 15:46:40, Download started at 15:46:41, completed at 15:50:05 Together (2025).avi Requested 15:50:30, Ready at 15:58:01, Download started at 15:58:03, completed at 16:00:42 Can you tell me if there were other downloads during this period? And the multiple files you mention - were these separate episodes / movies that you were selecting and starting downloads for and having a number in progress ? I cannot see this in the log - can you tell me when you did that within the period covered by the log file (2025-11-25 15:08:35 to 16:01:49) Edited November 26, 2025 by sa2000
