Teredactle 41 Posted November 22, 2025 Posted November 22, 2025 Hi, I'd like to change my "show fields" settings for several libraries to only File Name and Runtime. This seems impossible, as the library settings is defaulted to the Title and Year selections, which are useless for Home Video Photo libraries where the ones above make the most sense (for me anyway). How do I go about resetting this default for the libraries in question? Library folder structure is set up like this: YYYY 01-Jan 02-Feb etc... so many subfolders where this default need to be changed, and don't have the cycles to manually change it. I've searched and can't find this, can someone tell me where do I change this in the settings? TY
Luke 42287 Posted November 24, 2025 Posted November 24, 2025 Hi, there is currently no way to do this but this question has come up before and it's possible for future updates. Thanks.
