Eigeplackter 93 Posted November 22, 2025 Posted November 22, 2025 Hi, I prefer custom covers in my Emby libraries and invest a lot of time. I only use PNG images, but Emby downloads JPG posters into the media folders, even though I have disabled scraping all metadata in Emby. I use TMM for the metadata. When I started writing the post: Same folder this morning: I'm on latest stable Version 4.9.1.90 Can provide the log files via pm. Library settings are: Glad for any help as its really annoying. Regards Eigeplackter
GrimReaper 4926 Posted November 22, 2025 Posted November 22, 2025 I've used exact same setup for years (TMM backend-Emby frontend) - though with jpg artwork (few random pngs that I have are still in place) - and Emby not once overwrote them. What you could try doing is enable all Emby's internal artwork fetchers and then disable them again, in case sever update caused some shenanigans. Else, I'd assume hardly any guess could be made without logs provided.
Eigeplackter 93 Posted November 22, 2025 Author Posted November 22, 2025 Tried that, didn't change behaviour. Emby scans and downloads new jpeg. I can provide log via pn, just not public,
Luke 42288 Posted November 22, 2025 Posted November 22, 2025 Hi, what makes you think Emby downloads new images?
Eigeplackter 93 Posted November 22, 2025 Author Posted November 22, 2025 I went to bed at 3am, shortly after the 1st screenshot was taken- Folder was clean of season.jpgs and when I got up around 12pm there are season.jpg files back in place. Nothing except Emby was running around that time, TMM was closed and doesnt scrape w/o interaction for me. Emby restarts daily around 5:30am, at 6am the planned job Detect Episode Intros runs.
Happy2Play 9814 Posted November 22, 2025 Posted November 22, 2025 Would need to see the corresponding server log. Do you have more than one library pointing to this path?
Eigeplackter 93 Posted November 22, 2025 Author Posted November 22, 2025 Does it have to be an extended log ? If though I would activate that option tonight and check the log tomorrow.
Eigeplackter 93 Posted November 23, 2025 Author Posted November 23, 2025 Same procedure this morning, whatever it is, it starts at 9am and ran till 9:39am. Log sent @Happy2Play& @Luke
Luke 42288 Posted November 23, 2025 Posted November 23, 2025 From the PM it sounds like you may have found something else on your system that is responsible.
Solution Eigeplackter 93 Posted November 24, 2025 Author Solution Posted November 24, 2025 That's correct. As I wasn't able to find a reason for cover downloads by Emby and Happy2Play confirmed there's no log entry stating an unwanted cover download by Emby I had a flash of inspiration. And guess what ... The culprit wasn't Emby, it's the Aaaars. For anyone coming over this thread, by google or for whatever reason, here's the solution: Thanks for the support @Happy2Playand @Luke 2
