QPMReinhard 0 Posted November 21, 2025 Posted November 21, 2025 The Problem is, that my Samsumg TV can not connect to the emby-server. IP Range and Submask is checked. a ping from the empy to the Television works, but i can't see the television in he "Play to" Devices. There is also no ip from the television in any logfiles... ? And how can get the text for the movie files in "Directories" Bigger ? The Emby runs on Debian 12. and it works a view days aop.
Luke 42242 Posted November 21, 2025 Posted November 21, 2025 Hi there, have you tried using the Emby Samsung app?
QPMReinhard 0 Posted November 22, 2025 Author Posted November 22, 2025 no, may this be a problem with the emby rights ?
Luke 42242 Posted November 24, 2025 Posted November 24, 2025 On 11/22/2025 at 7:49 AM, QPMReinhard said: no, may this be a problem with the emby rights ? HI, I'm not sure what your issue is yet. I'm just suggesting something that might be easier, which is to just use the app.
Luke 42242 Posted November 24, 2025 Posted November 24, 2025 For DLNA, do you need to enable something on the TV so that it will advertise itself on your network?
