vaise 340 Posted November 20, 2025 Posted November 20, 2025 I’m doing my bit and converted all TV’s to use Emby for Android unified client. my issue is the deleting of recorded tv. From the recordedTV strip on main screen, select a show, then to delete you have to / Press right three times to go to three dots. press enter press down 8 times to get to delete. press enter press right to last played, and another enter. 15 button pressed. Please add it to the first screen before the three dots, text to the favourite heart?
Luke 42241 Posted November 21, 2025 Posted November 21, 2025 Hi, have you tried the long press context menu? It is available in lots of places.
vaise 340 Posted November 21, 2025 Author Posted November 21, 2025 Can you explain exactly. As holing ok or three lines on remote does not offer anything useful for this issue.
Luke 42241 Posted November 21, 2025 Posted November 21, 2025 When a poster is highlighted try using the long press menu at that point.
vaise 340 Posted November 21, 2025 Author Posted November 21, 2025 So one long press, then 8 downs to get to the delete. Past all the things no one in my family has ever used before. in a PVR, you watch something, then you delete it. Not shuffle, add to playlist, mark played, download, download to or convert. For a real PVR mode, Delete should be on the main screen. After you click it.
Luke 42241 Posted November 21, 2025 Posted November 21, 2025 More options to control that are certainly possible for the future.
