Skuld 2 Posted November 19, 2025 Posted November 19, 2025 Hi guys, I changed the host for my Emby Docker container, and now hardware acceleration is missing. Originally, I set up my Emby Docker container via Compose directly on a Proxmox host, with the NVIDIA driver, Docker toolkit, and everything else installed, and it worked perfectly. For various reasons, I decided to move the Emby service to a VM on the Proxmox host. I configured GPU passthrough to the VM, installed the NVIDIA driver and toolkit on the VM, and transferred all Emby files. However, the UI no longer shows a hardware transcoder. Running docker run --rm --runtime=nvidia --gpus all ubuntu nvidia-smi works as expected. I’m a bit lost since the underlying setup, Compose YAML, and files haven’t changed.
Luke 42242 Posted November 19, 2025 Posted November 19, 2025 Hi, sounds like you need to configure the VM to pass it through ? 1
Skuld 2 Posted November 19, 2025 Author Posted November 19, 2025 (edited) 12 minutes ago, Skuld said: I configured GPU passthrough to the VM, installed the NVIDIA driver and toolkit on the VM, and transferred all Emby files Inside the vm and then inside a container i am able to run "docker run --rm --runtime=nvidia --gpus all ubuntu nvidia-smi" and it runs like expected. I doubt that this would work if passthrough was not done Edited November 19, 2025 by Skuld
Skuld 2 Posted November 20, 2025 Author Posted November 20, 2025 Please, i am poaking in every direction trying to find the cause. What does emby accesses on linux devices so i can maybe run a testworkload inside the container with a attached console, like /dev/nvidia0 or something.
Skuld 2 Posted November 20, 2025 Author Posted November 20, 2025 I am able to run NVDEC & NVENC inside the vm and while doing so nvidia-smi lists a process
Skuld 2 Posted November 20, 2025 Author Posted November 20, 2025 This is from inside the emby docker container: ffmpeg -encoders | grep nvenc ffmpeg version 5.1-emby_2023_06_25_p4 Copyright (c) 2000-2022 the FFmpeg developers and softworkz for Emby LLC built with gcc 10.3.0 (crosstool-NG 1.25.0) Execution Date: 2025-11-20 19:23:38 V....D h264_nvenc NVIDIA NVENC H.264 encoder (codec h264) V....D hevc_nvenc NVIDIA NVENC hevc encoder (codec hevc) EXIT / # ffmpeg -hwaccels ffmpeg version 5.1-emby_2023_06_25_p4 Copyright (c) 2000-2022 the FFmpeg developers and softworkz for Emby LLC built with gcc 10.3.0 (crosstool-NG 1.25.0) Execution Date: 2025-11-20 19:23:46 Hardware acceleration methods: cuda vaapi qsv drm opencl EXIT
Skuld 2 Posted November 20, 2025 Author Posted November 20, 2025 I saw something in the logs and tryed it, this is from inside the container: /bin/ffdetect -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 nvencdec -print_format json ffdetect version 5.1-emby_2023_06_25_p4 Copyright (c) 2018-2022 softworkz for Emby LLC built with gcc 10.3.0 (crosstool-NG 1.25.0) configuration: --cc=x86_64-emby-linux-gnu-gcc --prefix=/home/embybuilder/Buildbot/x64/ffmpeg-x64/staging --disable-alsa --disable-doc --disable-ffplay --disable-gnutls --disable-libpulse --disable-librtmp --disable-libxcb --disable-openssl --disable-vdpau --disable-vulkan --disable-xlib --enable-chromaprint --enable-fontconfig --enable-gpl --enable-iconv --enable-libaribb24 --enable-libass --enable-libdav1d --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libzvbi --enable-mbedtls --enable-pic --enable-version3 --enable-libtesseract --enable-cuda-llvm --enable-cuvid --enable-libdrm --enable-libmfx --enable-nvdec --enable-nvenc --enable-vaapi --enable-opencl --enable-cross-compile --cross-prefix=x86_64-emby-linux-gnu- --arch=x86_64 --target-os=linux --enable-shared --disable-static --pkg-config=pkg-config --pkg-config-flags=--static --extra-libs='-ldl -lm -lstdc++ -lsharpyuv -pthread' --disable-debug libavutil 57. 28.100 / 57. 28.100 { "ProgramVersion": { "Version": "5.1-emby_2023_06_25_p4", "Copyright": "Copyright (c) 2018-2022 softworkz for Emby Llc", "Compiler": "gcc 10.3.0 (crosstool-NG 1.25.0)", "Configuration": "--cc=x86_64-emby-linux-gnu-gcc --prefix=/home/embybuilder/Buildbot/x64/ffmpeg-x64/staging --disable-alsa --disable-doc --disable-ffplay --disable-gnutls --disable-libpulse --disable-librtmp --disable-libxcb --disable-openssl --disable-vdpau --disable-vulkan --disable-xlib --enable-chromaprint --enable-fontconfig --enable-gpl --enable-iconv --enable-libaribb24 --enable-libass --enable-libdav1d --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libzvbi --enable-mbedtls --enable-pic --enable-version3 --enable-libtesseract --enable-cuda-llvm --enable-cuvid --enable-libdrm --enable-libmfx --enable-nvdec --enable-nvenc --enable-vaapi --enable-opencl --enable-cross-compile --cross-prefix=x86_64-emby-linux-gnu- --arch=x86_64 --target-os=linux --enable-shared --disable-static --pkg-config=pkg-config --pkg-config-flags=--static --extra-libs='-ldl -lm -lstdc++ -lsharpyuv -pthread' --disable-debug" Cannot load libcuda.so.1 Error loading CUDA functions }, "Error": { "Number": -1, "Message": "Operation not permitted" }, "Log": [ { "Level": 16, "Category": 0, "Message": "Cannot load libcuda.so.1" }, { "Level": 16, "Category": 0, "Message": "Error loading CUDA functions" } ] } My docker yml is: version: "2.3" services: emby: image: emby/embyserver stdin_open: true tty: true container_name: embyserver runtime: nvidia # Expose NVIDIA GPUs environment: - UID=1000 #1003# The UID to run emby as (default: 2) - GID=1000 #100# The GID to run emby as (default 2) - GIDLIST=40,992 # A comma-separated list of additional GIDs to run emby as (default: 2) - NVIDIA_VISIBLE_DEVICES=all - NVIDIA_DRIVER_CAPABILITIES=all volumes: - /opt/docker/mounted_storage/emby:/config # Configuration directory - /mnt/Videos:/mnt/Videos # Media directory - /mnt/ZFS1/transcoding-temp:/embytemp ports: - 8096:8096 # HTTP port - 8920:8920 # HTTPS port devices: - /dev/dri:/dev/dri # VAAPI/NVDEC/NVENC render nodes restart: unless-stopped
Luke 42242 Posted November 22, 2025 Posted November 22, 2025 Can you try our native package directly on the host machine to see how that compares?
Solution darkassassin07 674 Posted November 22, 2025 Solution Posted November 22, 2025 (edited) Potentially related. I was getting the same permission error in my logs. Edited November 22, 2025 by darkassassin07 1
Skuld 2 Posted November 22, 2025 Author Posted November 22, 2025 Legendary hint from @darkassassin07, i did what he did and this solved it. i also changed version: "2.3" to version: "3.8". 15 hours ago, darkassassin07 said: Solved! My Emby compose file had: runtime: nvidia # Expose NVIDIA GPUs Tdarr on the otherhand used: deploy: resources: reservations: devices: - driver: nvidia count: all capabilities: - gpu I had tried adding the deploy section to emby, but hadn't removed the runtime arg. Once I properly swapped them out, Embys container saw the gpu in the correct groups and now both Emby and Tdarr are able to use the gpu as expected. (I had also tried stopping Tdarr to see if it was somehow 'reserving' the gpu and preventing Emby from using it, as the term 'reservations' above would imply, but that was not the case) @guunterWhich of the two do you have, or are you using something different? 1
darkassassin07 674 Posted November 22, 2025 Posted November 22, 2025 Hmm. That's two of us now. I wonder why the Nvidia runtime no longer seems to work in the official emby container. When I've got some more free time I'm going to try the linxuserver.io version on my system just to see if it can use the runtime correctly. Not sure if this is the runtime being broken or somehow the implementation within emby is flawed. At least this is workin for now.
Skuld 2 Posted November 22, 2025 Author Posted November 22, 2025 Looks like that we are not the only ones with this problem, all over other forums reports for this issue appear. But there does not seem to be a official drop of support for the "old" implementation, but since it is depricated anyway it probably makes sense to change it in the setup guide as well.
guunter 49 Posted November 22, 2025 Posted November 22, 2025 35 minutes ago, darkassassin07 said: Hmm. That's two of us now. I wonder why the Nvidia runtime no longer seems to work in the official emby container. When I've got some more free time I'm going to try the linxuserver.io version on my system just to see if it can use the runtime correctly. Not sure if this is the runtime being broken or somehow the implementation within emby is flawed. At least this is workin for now. You should. They do have more tweaks to their image for hw support. I also use them for my other dockers so all my yaml can be consistent.
Luke 42242 Posted November 22, 2025 Posted November 22, 2025 Hi, we will look at updating our instructions. Thanks.
