darkassassin07 674 Posted November 17, 2025 Posted November 17, 2025 (edited) I noticed last night some things were converting very slowly and realized they were using the cpu to do it. Digging a bit more this morning, it seems emby is erroring while running ffdetect during startup. embyserver.txt: 2025-11-17 09:20:46.171 Info NvidiaCodecProvider: ProcessRun 'ffdetect_nvencdec' Execute: /bin/ffdetect -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 nvencdec -print_format json 2025-11-17 09:20:46.172 Info NvidiaCodecProvider: ProcessRun 'ffdetect_nvencdec' Process exited with code 1 - Failed When ran manually using docker exec I get: ffdetect version 5.1-emby_2023_06_25_p4 Copyright (c) 2018-2022 softworkz for Emby LLC built with gcc 10.3.0 (crosstool-NG 1.25.0) configuration: --cc=x86_64-emby-linux-gnu-gcc --prefix=/home/embybuilder/Buildbot/x64/ffmpeg-x64/staging --disable-alsa --disable-doc --disable-ffplay --disable-gnutls --disable-libpulse --disable-librtmp --disable-libxcb --disable-openssl --disable-vdpau --disable-vulkan --disable-xlib --enable-chromaprint --enable-fontconfig --enable-gpl --enable-iconv --enable-libaribb24 --enable-libass --enable-libdav1d --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libzvbi --enable-mbedtls --enable-pic --enable-version3 --enable-libtesseract --enable-cuda-llvm --enable-cuvid --enable-libdrm --enable-libmfx --enable-nvdec --enable-nvenc --enable-vaapi --enable-opencl --enable-cross-compile --cross-prefix=x86_64-emby-linux-gnu- --arch=x86_64 --target-os=linux --enable-shared --disable-static --pkg-config=pkg-config --pkg-config-flags=--static --extra-libs='-ldl -lm -lstdc++ -lsharpyuv -pthread' --disable-debug libavutil 57. 28.100 / 57. 28.100 Cannot load libcuda.so.1 Error loading CUDA functions { "ProgramVersion": { "Version": "5.1-emby_2023_06_25_p4", "Copyright": "Copyright (c) 2018-2022 softworkz for Emby Llc", "Compiler": "gcc 10.3.0 (crosstool-NG 1.25.0)", "Configuration": "--cc=x86_64-emby-linux-gnu-gcc --prefix=/home/embybuilder/Buildbot/x64/ffmpeg-x64/staging --disable-alsa --disable-doc --disable-ffplay --disable-gnutls --disable-libpulse --disable-librtmp --disable-libxcb --disable-openssl --disable-vdpau --disable-vulkan --disable-xlib --enable-chromaprint --enable-fontconfig --enable-gpl --enable-iconv --enable-libaribb24 --enable-libass --enable-libdav1d --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libzvbi --enable-mbedtls --enable-pic --enable-version3 --enable-libtesseract --enable-cuda-llvm --enable-cuvid --enable-libdrm --enable-libmfx --enable-nvdec --enable-nvenc --enable-vaapi --enable-opencl --enable-cross-compile --cross-prefix=x86_64-emby-linux-gnu- --arch=x86_64 --target-os=linux --enable-shared --disable-static --pkg-config=pkg-config --pkg-config-flags=--static --extra-libs='-ldl -lm -lstdc++ -lsharpyuv -pthread' --disable-debug" }, "Error": { "Number": -1, "Message": "Operation not permitted" }, "Log": [ { "Level": 16, "Category": 0, "Message": "Cannot load libcuda.so.1" }, { "Level": 16, "Category": 0, "Message": "Error loading CUDA functions" } I'm not sure what could have changed to introduce a permission error, or how to fix it. This is within a docker container, so here is my compose file, which hasn't changed in a long time and was previously transcoding using hardware just fine: services: emby: image: emby/embyserver:latest container_name: emby runtime: nvidia # Expose NVIDIA GPUs environment: - UID=1000 # The UID to run emby as (default: 2) - GID=1000 # The GID to run emby as (default 2) - GIDLIST=1000,44,104 - NVIDIA_VISIBLE_DEVICES=all - NVIDIA_DRIVER_CAPABILITIES=all - TZ=America/Vancouver volumes: - /srv/emby/programdata:/config # Configuration directory - /mnt/Drobo/Media:/Media # Media directory - /mnt/Backups/Emby:/Backups #backup directory - /mnt/Cache/Emby_Cache:/Cache #cache - /mnt/Cache/Transcoding_Temp:/Transcoding_temp #transcoding directory #- type: tmpfs #target: /Transcoding_temp # ports: # - 8096:8096 # HTTP port devices: - /dev/dri:/dev/dri # VAAPI/NVDEC/NVENC render nodes networks: arr: ipv4_address: 172.18.0.94 restart: unless-stopped labels: com.centurylinklabs.watchtower.enable: true networks: arr: external: true Emby Server v4.9.1.90 on debian 12 Docker engine: 29.0.2 Containerd: 2.1.5 embyserver.txt hardware_detection-63898968046.txt Edited November 17, 2025 by darkassassin07
Luke 42242 Posted November 17, 2025 Posted November 17, 2025 Hi, is that the official emby docker container?
darkassassin07 674 Posted November 18, 2025 Author Posted November 18, 2025 (edited) From the above compose: "image: emby/embyserver:latest" Pretty sure. Is this not it? That's what's listed at: Https://hub.docker.com/r/emby/embyserver Which is whats linked to from: https://emby.media/docker-server.html Edited November 18, 2025 by darkassassin07
darkassassin07 674 Posted November 18, 2025 Author Posted November 18, 2025 I've bee able to confirm other docker containers are successfully using hardware transcoding, namely Tdarr; it just seems to be the Emby container running into this issue. I then tried reverting to 4.9.1.80 and then 4.9.1.36; both encountered the same error in their hardware detection logs. Perhaps this is an issue/interaction with the latest nvidia-container-toolkit (v1.18.0-1) which I updated to Nov 9th along with my usual 'apt-get upgrade'? Has anyone got an Emby docker container with Nvidia hardware transcoding working that I can compare against? What versions are you running?
guunter 49 Posted November 18, 2025 Posted November 18, 2025 1 hour ago, darkassassin07 said: I've bee able to confirm other docker containers are successfully using hardware transcoding, namely Tdarr; it just seems to be the Emby container running into this issue. I then tried reverting to 4.9.1.80 and then 4.9.1.36; both encountered the same error in their hardware detection logs. Perhaps this is an issue/interaction with the latest nvidia-container-toolkit (v1.18.0-1) which I updated to Nov 9th along with my usual 'apt-get upgrade'? Has anyone got an Emby docker container with Nvidia hardware transcoding working that I can compare against? What versions are you running? Hardware transcoding works for me on 4.9.2.6 beta. Using a Tesla T4. nvidia-container-toolkit v1.18.0-1. Driver version 580.95.05
guunter 49 Posted November 18, 2025 Posted November 18, 2025 Btw you do not need /dev/dri:/dev/dri when you're using nvidia in your docker compose.
darkassassin07 674 Posted November 18, 2025 Author Posted November 18, 2025 (edited) Hmm. That leaves me a little unsure where to look next. I do seem to be running an older version of the driver (535.247.01-1~deb12u1) which is the newest apt finds, but I'm not sure why that would cause this or how to update beyond what apt found (I'm a bit fresh to Linux in general). /edit: beta 4.9.2.6 throws the same permission error. The test nvidia provides: sudo docker run --rm --runtime=nvidia --gpus all ubuntu nvidia-smi Works just fine. I don't know where else to look. Edited November 18, 2025 by darkassassin07
guunter 49 Posted November 19, 2025 Posted November 19, 2025 Are you running the script for your 3080 to unlock the 2x stream limit?
darkassassin07 674 Posted November 19, 2025 Author Posted November 19, 2025 23 minutes ago, guunter said: Are you running the script for your 3080 to unlock the 2x stream limit? I don't recall doing anything like that. I haven't really needed more than 2 streams tho. My main concern is just getting it to work at all rn. I put all my focus into fixing my openvpn server lastnight, hopefully I'll have time to dive more into this in the next couple days. I'm going to attempt to re-install the drivers+container toolkit. Maybe that'll get me somewhere I don't understand why tdarr is using the card to transcode just fine, but emby fails. I would think both would fail if it were a driver issue, but I don't know what else to do.
darkassassin07 674 Posted November 21, 2025 Author Posted November 21, 2025 Sort of? When I 'ls -ln /dev/dri': on the host and via exec in my tdarr container, card0 and renderD128 are in groups 44 and 105 respectively in both places. In the emby container however, both are in group 0. I presume that's the cause of the permission errors, but I don't know why it's like that or how to fix it. I've reinstalled the drivers and container-toolkit for good measure, but no change.
Solution darkassassin07 674 Posted November 21, 2025 Author Solution Posted November 21, 2025 Solved! My Emby compose file had: runtime: nvidia # Expose NVIDIA GPUs Tdarr on the otherhand used: deploy: resources: reservations: devices: - driver: nvidia count: all capabilities: - gpu I had tried adding the deploy section to emby, but hadn't removed the runtime arg. Once I properly swapped them out, Embys container saw the gpu in the correct groups and now both Emby and Tdarr are able to use the gpu as expected. (I had also tried stopping Tdarr to see if it was somehow 'reserving' the gpu and preventing Emby from using it, as the term 'reservations' above would imply, but that was not the case) @guunterWhich of the two do you have, or are you using something different? 2
guunter 49 Posted November 22, 2025 Posted November 22, 2025 9 hours ago, darkassassin07 said: Solved! My Emby compose file had: runtime: nvidia # Expose NVIDIA GPUs Tdarr on the otherhand used: deploy: resources: reservations: devices: - driver: nvidia count: all capabilities: - gpu I had tried adding the deploy section to emby, but hadn't removed the runtime arg. Once I properly swapped them out, Embys container saw the gpu in the correct groups and now both Emby and Tdarr are able to use the gpu as expected. (I had also tried stopping Tdarr to see if it was somehow 'reserving' the gpu and preventing Emby from using it, as the term 'reservations' above would imply, but that was not the case) @guunterWhich of the two do you have, or are you using something different? I use the linuxserver.io image. --- services: emby: image: lscr.io/linuxserver/emby:beta container_name: emby runtime: nvidia environment: - PUID=1001 - PGID=1001 - TZ=America/Los_Angeles - NVIDIA_VISIBLE_DEVICES=all volumes: - /opt/appdata/emby:/config - /mnt/nas/media/:/mnt/nas/media/:ro - /dev/shm:/transcoding ports: - 8096:8096 - 8920:8920 #optional restart: unless-stopped
