DaN 49 Posted November 17, 2025 Posted November 17, 2025 Studio option is removed from filter after recent update, please restore it back again.
GrimReaper 4895 Posted November 17, 2025 Posted November 17, 2025 (edited) I'm still seeing it on 4.9.1.90 - where are you looking for it? Edited November 17, 2025 by GrimReaper Cross-posted
DaN 49 Posted November 21, 2025 Author Posted November 21, 2025 This is the filter when selecting one of the movie cast, and emby displays only contents related to this actor. I attached a screenshot. Studio filter was here before, but it was removed in 4.9.1.90 or maybe earlier.
GrimReaper 4895 Posted November 21, 2025 Posted November 21, 2025 (edited) I can second that, not only Studio but Genre and Tag filters are missing from the same dialog, as well. @Luke 4.8.11.0 4.9.1.90 Edited November 21, 2025 by GrimReaper 1
Happy2Play 9811 Posted November 21, 2025 Posted November 21, 2025 I will assume Folder view as those names are not Media.
GrimReaper 4895 Posted November 21, 2025 Posted November 21, 2025 1 minute ago, Happy2Play said: I will assume Folder view as those names are not Media. Not. Actor view>click Movies header.
Happy2Play 9811 Posted November 21, 2025 Posted November 21, 2025 Just now, GrimReaper said: Not. Actor view>click Movies header. Okay with that context yes that view is missing that info. 2
DaN 49 Posted November 22, 2025 Author Posted November 22, 2025 Shall I expect a restoration for these filters any time soon?
DaN 49 Posted November 22, 2025 Author Posted November 22, 2025 Thank you all for support, and thank you @Lukefor considering 1
Solution DaN 49 Posted January 11 Author Solution Posted January 11 Restored now with the recent update; thank you so much 1
