Damsdu77 4 Posted November 17, 2025 Posted November 17, 2025 Hi, I've noticed that the vertical resolution displayed on the video details page is incorrect when it's below 480p: even if the actual height is 294 pixels, Emby displays it as 480p. Isn't it possible to display the actual height? In this instance, the actual resolution of this video is 712x296, therefore lower than 480p Thanks in advance. Regards.
GrimReaper 4926 Posted November 17, 2025 Posted November 17, 2025 (edited) Been a long time since this was mentioned, lemme see if I still remember those values correctly: 700-1270-1900-3800 @ebrdoes that sound about right? Anyway, IIRC Emby uses Width/horizontal value, not Height/vertical value for resolution, with delimiters being those stated above, i.e.: SD<700px, 480p<1270px, 720p<1900px, 1080p<3800px, 4K>3800px width. In your example, it's 712px width, hence 480p; if it were few px less (<700), it'd be marked SD res. Edited November 17, 2025 by GrimReaper
Happy2Play 9814 Posted November 17, 2025 Posted November 17, 2025 (edited) 7 minutes ago, Luke said: Hi, what is the resolution? 1 hour ago, Damsdu77 said: In this instance, the actual resolution of this video is 712x296, therefore lower than 480p But similar topics have come up many times over the years. Edited November 17, 2025 by Happy2Play
Happy2Play 9814 Posted November 17, 2025 Posted November 17, 2025 (edited) From Old topics so might have slightly changed over time but basically the same as what Grim posted above. On 10/3/2017 at 1:29 PM, speechles said: https://github.com/MediaBrowser/Emby/blob/master/MediaBrowser.Controller/Entities/Video.cs#L783-L808 if (videoStream != null) { if (videoStream.Width.HasValue) { if (videoStream.Width.Value >= 3800) { terms.Add("4K"); } else if (videoStream.Width.Value >= 1900) { terms.Add("1080P"); } else if (videoStream.Width.Value >= 1270) { terms.Add("720P"); } else if (videoStream.Width.Value >= 700) { terms.Add("480P"); } else { terms.Add("SD"); } } } Understand now? Perhaps this part of the code should be refactored to make use of videoStream.Height.Value in these evaluations too? Edited November 17, 2025 by Happy2Play
Damsdu77 4 Posted November 17, 2025 Author Posted November 17, 2025 51 minutes ago, GrimReaper said: Been a long time since this was mentioned, lemme see if I still remember those values correctly: 700-1270-1900-3800 @ebrdoes that sound about right? Anyway, IIRC Emby uses Width/horizontal value, not Height/vertical value for resolution, with delimiters being those stated above, i.e.: SD<700px, 480p<1270px, 720p<1900px, 1080p<3800px, 4K>3800px width. In your example, it's 712px width, hence 480p; if it were few px less (<700), it'd be marked SD res. If that's indeed the logic that was applied in Emby, then I question its basis, because generally when we talk about 1080p or 720p, we're referring to the number of vertical lines, not the number of horizontal pixels. Why would it be different for 480p? But perhaps I misunderstood your argument. Sources: https://en.wikipedia.org/wiki/480p, https://en.wikipedia.org/wiki/720p, https://en.wikipedia.org/wiki/1080p PS: Sorry for posting in the wrong section PPS: Version in question: not Windows but Linux (on a Raspberry Pi)
