Mkilbride 86 Posted November 17, 2025 Posted November 17, 2025 It doesn't seem to matter anymore. Randomly releases will hitch for no real reason, or audio desyncs, I've cleared cache, even did a system format of the Shield, changed all the HDMI Cables. But it just doesn't matter. Randomly, for no reason at all, a release that is direct playing will just pause in the Android App. But then, if I switch over to the AndroidTV App - It just works. But occasionally I will get some hitching. It is a direct connection to my media server via Ethernet cable. This does not happen in Plex, or Jellyfin. Both play files flawlessly and without issue. However, I paid for Emby Premiere and use it so my friends can enjoy my media server, and over the years it has only gotten worse support. Sometimes when I start a file, Emby itself will just crash and re-load, then I play it again and it just works. It also has issues with needing to burn in ASS/SSA subtitles for formatting or when they display, I get huge slowdowns and the videos can stutter like mad. Plex direct plays them without issue. My PC is running a 5800X3D and a 5090. I am running the latest builds of Emby Server. I don't want to use Plex or Jellyfin, as Plex is riddled with ads and nonsense features I do not want and Jellyfin just isn't what I want. I paid for Emby. I've been trying to ignore these issues for years, but it's becoming very difficult lately when I get people complaining to me about why movies are freezing or skipping. What is going on with Emby Development? There's been basic features requested for 5 years that still aren't implemented, like selecting a series audio / subtitle track en masse. I'm going to have use Plex for playing movies I guess though because it's just become too annoying. And no, log files will not help. Over the years, I've posted logfiles for you, given you samples of the media I was trying to play and nothing comes of it. 1
Luke 42241 Posted November 17, 2025 Posted November 17, 2025 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Gilgamesh_48 1243 Posted November 17, 2025 Posted November 17, 2025 FWIW: I have been almost exclusively using EMBY on my Shield and I have zero problems like you describe. I do have a few issues but I have virtually no playback issues. The one thing I almost always think of when confronted with playback problems like you describe is connection issues. Your server should NEVER be connected wirelessly and weird problems happen when it is. Also even if you have a very strong and stable signal a wireless connection to it a client can have problems ranging from jus a little glitchy to virtually total failure of playback because wireless connections are easily interfered with by just random noise from many different things in your house of even a neighbor's if you live close enough. I have even seen one case where interference was caused by a fireplace poker hanging stationary in its rack. (If anyone is interested in how that happened I am happy to expound but I use enough words to bore anybody and I do not want to detract from this thread by getting too far afield) If your server or your Shield is connected wirelessly then I suggest you connect them wired to eliminate the possibility of wireless glitches. Beyond that you should follow the instructions that have been given here for supplying additional needed data and the experts here may well be able to help. 1
monkeyfella 14 Posted November 19, 2025 Posted November 19, 2025 On 11/17/2025 at 6:08 PM, Gilgamesh_48 said: FWIW: I have been almost exclusively using EMBY on my Shield and I have zero problems like you describe. I do have a few issues but I have virtually no playback issues. The one thing I almost always think of when confronted with playback problems like you describe is connection issues. Your server should NEVER be connected wirelessly and weird problems happen when it is. Also even if you have a very strong and stable signal a wireless connection to it a client can have problems ranging from jus a little glitchy to virtually total failure of playback because wireless connections are easily interfered with by just random noise from many different things in your house of even a neighbor's if you live close enough. I have even seen one case where interference was caused by a fireplace poker hanging stationary in its rack. (If anyone is interested in how that happened I am happy to expound but I use enough words to bore anybody and I do not want to detract from this thread by getting too far afield) If your server or your Shield is connected wirelessly then I suggest you connect them wired to eliminate the possibility of wireless glitches. Beyond that you should follow the instructions that have been given here for supplying additional needed data and the experts here may well be able to help. I have been using the android tv app without issues for years.. it’s the new android version that has problems. Videos that stutter and subtitles that doesn’t work.
Guest Posted November 19, 2025 Posted November 19, 2025 1 hour ago, monkeyfella said: I have been using the android tv app without issues for years.. it’s the new android version that has problems. Videos that stutter and subtitles that doesn’t work. Same experience here. Shieldtv pro using androidTV app for years without issues. The standard android app on the shieldtv has glitchy audio/video and crashes once a week at least.
Gilgamesh_48 1243 Posted November 19, 2025 Posted November 19, 2025 2 hours ago, monkeyfella said: I have been using the android tv app without issues for years.. it’s the new android version that has problems. Videos that stutter and subtitles that doesn’t work. I use the "new" version exclusively on my Shield and have exactly zero problems like you describe. To be fair I do not use high bitrate files at all and the subs I use are all imbedded in MKV files. Even three hour movies are less that 4gb and the vast majority are less than 2gb.
Luke 42241 Posted January 19 Posted January 19 For video stuttering, please try Emby for Android 3.5.25 and let us know how that compares: https://emby.media/emby-for-android.html Thanks.
popy 73 Posted February 6 Posted February 6 (edited) Same issue here on the shield pro 2019 with Emby for Android TV On an episode (~50min) it just pauses (video and audio freezes, sometimes multiple times) . The UI is responsive and if I forward/rewind just a few secs, and maybe (not always), it starts to play again. On the shield I have no issues with other streaming apps. Also my network is ok. @Lukeis this also a known issue on the Android TV version and a fix for this incoming? Edited February 6 by popy
Mkilbride 86 Posted February 6 Author Posted February 6 I've been dealing with this for years. Never found a solution, but doing what you said can help.
Luke 42241 Posted February 6 Posted February 6 4 hours ago, popy said: Same issue here on the shield pro 2019 with Emby for Android TV On an episode (~50min) it just pauses (video and audio freezes, sometimes multiple times) . The UI is responsive and if I forward/rewind just a few secs, and maybe (not always), it starts to play again. On the shield I have no issues with other streaming apps. Also my network is ok. @Lukeis this also a known issue on the Android TV version and a fix for this incoming? @popy Hi there, please attach the Emby server log from when the problem occurred: How to Report a Problem Thanks!
popy 73 Posted February 20 Posted February 20 @Lukeit happend again. Yesterday around 22:28 (a few times). I have attached the logs. My system is an unraid with the emby docker container and hw transcoding setup like this: https://forums.unraid.net/topic/101969-guide-setup-emby-with-hw-transcoding-on-unraid-remote-access-through-reverse-proxy-using-swag/ and checked by settings an low resolution on an client -> server dashboard is showing HW transcoding (green icon). I have an idea and test the following now: On my second client i have not noticed the issue (same nvidia shield pro incl. same firmware and emby app). But the android tv app setting: settings -> playback -> audio output -> is set to "Auto". On my client with the issue (see logs) it was set to something "Downmix to DTS...". The files i am playing have mostly aac audio. If i played the same file on both maschines, on one (without the issue) it says "Direct play" for video and audio. On the maschine with the issue it said direct play just for video and transcoding for audio. After changing the setting to "Auto" it also says "direct play" for video and audio. Can you please check the logs for an issue regarding transcoding? Any other hint why it begins to stutter (i have noticed mostly at the end of an ~40 min video - last few minutes). thx logs_emby_server.zip
popy 73 Posted February 23 Posted February 23 For me it seems the issue is gone after changing the setting descibed in my post above to "Auto". I have watched ~9 epsiodes without an issue. @Mkilbridecan check this setting on your end? @LukeIt seems that if any part of the stream is reencoded (in my case audio and maybe because of that use other transport method) the issue appears. P.S.: i am using AndroidTV emby app with wired 2,5 GBE connection. All other real time services over this connection doesn't have any issue at all. Also iperf works full speed with zero errors.
js28194 42 Posted February 24 Posted February 24 (edited) On 2/23/2026 at 9:51 AM, popy said: P.S.: i am using AndroidTV emby app with wired 2,5 GBE connection. All other real time services over this connection doesn't have any issue at all. Also iperf works full speed with zero errors. So that alone is suspect as the Nvidia Shield Pro only has a 1GB ethernet port, so how are you getting "full speeds with zero errors" with a 2.5GB ethernet connection is amusing. https://www.nvidia.com/en-us/shield/shield-tv-pro/ Gigabit Ethernet HDMI 2.0b with HDCP 2.2 and CEC support Two USB 3.0 Ports (Type A) P.S I've been using these devices (exclusively) since 2015 over WiFI with ZERO issues so yeah.... Edited February 24 by js28194
popy 73 Posted February 24 Posted February 24 @Lukethx, please keep us updated. @js28194SURE i know it has an 1GBE connection. Sorry for not beeing clear. With an notebook and iperf i get full 2,5GBE over 3x 2,5 GBE switches. With the shield i get full 1GBE while not saturating my switches switching capacity. And as stated above, NO other streaming service has issues at all on the shield (and i am streaming also 4k DV HDR..., where the issue in emby occured on 1080p material).
ebr 16334 Posted February 24 Posted February 24 10 minutes ago, popy said: NO other streaming service has issues at all on the shield Hi. No other streaming service is accessing content on your network and your server... 1
popy 73 Posted February 24 Posted February 24 (edited) 1 hour ago, ebr said: Hi. No other streaming service is accessing content on your network and your server... Thanks, for teaching me how emby works Just wanted to say: I am sure my network is ok. Sorry for not being clearer about this. If it happens again, i will upload another log. Edited February 24 by popy 1
ebr 16334 Posted February 25 Posted February 25 21 hours ago, popy said: Thanks, for teaching me how emby works Hi. It is an important distinction as the two data paths are completely different but you were using one to justify the performance of another. 1
