NorthDegree 10 Posted November 16, 2025 Posted November 16, 2025 I am currently using emby for kodi next gen 10.1.2, running on Android device - i noticed there are other higher numbered versions..should i upgrade ?
quickmic 1709 Posted November 19, 2025 Posted November 19, 2025 (edited) Sooner or later yes, 10.X and 11.X versions are not compatible with Kodi 22.X. I always recommend updates, but in the end it's on you. Edited November 19, 2025 by quickmic
