Przemek 70 Posted November 13, 2025 Posted November 13, 2025 Hello, I want to assign one list to one user. When I try to add tag to one m3u list and then add tag in parental control to user see only that tag. He don't see other libraries. I cannot find a way to add tags to my libraries. It's possible?Addind tag to every movie or series is pointless. Regards.
Luke 42239 Posted November 13, 2025 Posted November 13, 2025 Hi, right, once you start using tags, you will be forced to tag quite a few things using either the block all or allow all option. This is something we plan to improve on in future updates. Thanks.
Przemek 70 Posted November 13, 2025 Author Posted November 13, 2025 2 minutes ago, Luke said: Hi, right, once you start using tags, you will be forced to tag quite a few things using either the block all or allow all option. This is something we plan to improve on in future updates. Thanks. So it's not possible to add tag to all librarie at once?
Luke 42239 Posted November 13, 2025 Posted November 13, 2025 42 minutes ago, Przemek said: So it's not possible to add tag to all librarie at once? Hi, not currently, no. 1
Przemek 70 Posted November 13, 2025 Author Posted November 13, 2025 But if I have two lists and add different tags to them, then I add in parental control to block with tag. It should work? One user will see everything with one list and second will see everything with second list. That's wright?
kanipek 230 Posted November 14, 2025 Posted November 14, 2025 4 hours ago, Przemek said: Hello, I want to assign one list to one user. When I try to add tag to one m3u list and then add tag in parental control to user see only that tag. He don't see other libraries. I cannot find a way to add tags to my libraries. It's possible?Addind tag to every movie or series is pointless. Regards. Have you tried the Bulky plugin? It will do what you want. If you have large libraries it will take awhile. Just let it run or better yet do it in small batches. What you will want to do IMO is come up with a tag to allow different users to have access to what you desire. Then in parental access do allow only that tag you chose for each user (User1-Allow for example). This way it's a single tag per user if that makes sense. You can use Bulky to add multiple tags at once. I am sure Emby will at some point be able to this natively until then this method works.
Solution Przemek 70 Posted November 14, 2025 Author Solution Posted November 14, 2025 8 hours ago, kanipek said: Have you tried the Bulky plugin? It will do what you want. If you have large libraries it will take awhile. Just let it run or better yet do it in small batches. What you will want to do IMO is come up with a tag to allow different users to have access to what you desire. Then in parental access do allow only that tag you chose for each user (User1-Allow for example). This way it's a single tag per user if that makes sense. You can use Bulky to add multiple tags at once. I am sure Emby will at some point be able to this natively until then this method works. Thanks but I test tag solution with blocking and it works perfect. Don't have to add tags to libraries and new tags for new content. Regards. 1
