Sorahl 7 Posted November 13, 2025 Posted November 13, 2025 I have a movie, with 7 items that are in the extras folder. Those items still show up as main movies in the folder for this group of movies. i've removed the whole library many times, refreshed metadata, can't figure out how to get this to list right.. any suggestions? John
Luke 42287 Posted November 13, 2025 Posted November 13, 2025 HI there, can you please provide a specific example? How to Report a Problem Thanks !
Sorahl 7 Posted November 13, 2025 Author Posted November 13, 2025 i have made sure that only the main movie is named movie (1938) or whatever. the extras are in extra folder (lowercase) with nothing on the names that could be confused with the movie
Sorahl 7 Posted November 13, 2025 Author Posted November 13, 2025 (edited) Here is a picture of how they are listed in Emby the arrow is above the movie, the items listed are the extras.. Notice their name.... now here is how they show up in the folder I don't know where its picking up the extra name detail - since i've changed that several iterations ago, and have removed the whole library several times and refreshed the metadata.. and ...thanks Edited November 13, 2025 by Sorahl
crusher11 1153 Posted November 14, 2025 Posted November 14, 2025 What's in the “Dr Syn - The Scarecrow of Romney Marsh (1963)” folder?
crusher11 1153 Posted November 14, 2025 Posted November 14, 2025 It doesn't have the same name as the folder. 1
Sorahl 7 Posted November 14, 2025 Author Posted November 14, 2025 I also found the movie listed in a duplicated directory... there is always a simple explanation - just need to keep looking
Luke 42287 Posted November 15, 2025 Posted November 15, 2025 12 hours ago, Sorahl said: I also found the movie listed in a duplicated directory... there is always a simple explanation - just need to keep looking Has this resolved your issue?
LostInTheFold 5 Posted February 14 Posted February 14 Hello, I am having this issue but only with one of my folders, I suspect there is something wrong with how I have structured the files/folder. If you could help me out, I would greatly appreciate it. If at all possible, I would really like to be able to maintain these in a single folder, but if not, I understand. I would also like to be able to maintain the numbering system to be able to identify which movie is first second and third etc from a naming perspective. It doesn't matter on the Emby interface side, but if for some reason I need to migrate or whatever and need to re-generate images and such, it will help organize things. Thanks much. Here is my foldername: 02/09/2026 11:26 PM <DIR> . 01/25/2025 12:14 AM <DIR> .. 02/14/2026 12:04 AM <DIR> Zatoichi There are 25 movies under this folder, as well as extras and trailers. so I will attach them so it doesn't make this huge. Dir of Zatoichi.txt Dir of Trailers.txt dir of extras.txt
Luke 42287 Posted February 15 Posted February 15 HI, what content type did you setup the library with?
LostInTheFold 5 Posted February 15 Posted February 15 This is under the movies category, I guess that wasn't completely clear. Thank you for responding on a weekend. Also, if it isn't clear, only the "extras" are showing up in the main movie display, not the trailers.
Luke 42287 Posted February 18 Posted February 18 OK in the options for that library, how are the automatic grouping options set?
LostInTheFold 5 Posted February 18 Posted February 18 I am assuming this is all you want to know. Thanks again.
Luke 42287 Posted February 18 Posted February 18 OK try setting the multi-version detection to be based on files only. Then run a library scan and see if that helps. Thanks.
LostInTheFold 5 Posted February 18 Posted February 18 Made the change as you can see below: Rescanned Library files, waited 10 minutes, and checked. Didn't see a difference. Rescanned Library files again, waited 10 minutes and checked again. These show up in latest as I have recently tried to remove and recopy them in the last day or so, previous to contacting you.
Luke 42287 Posted February 19 Posted February 19 OK the extras folder is to be used with individual movies. The Zatoichi folder is not a single movie folder because it has a lot of video files in it. So that's why extras end up showing as their own items.
LostInTheFold 5 Posted February 19 Posted February 19 OK. i know there are alternate folders that Emby recognizes for movie folders. Is there an option I can use for that? Or no? Do I need to break these out to individual folders? BTW, thanks for your help.
Luke 42287 Posted March 5 Posted March 5 On 2/19/2026 at 1:46 AM, LostInTheFold said: OK. i know there are alternate folders that Emby recognizes for movie folders. Is there an option I can use for that? Or no? Do I need to break these out to individual folders? BTW, thanks for your help. You would need to have each movie in it's own folder. Then in each movie folder, you could have extras underneath that. Does that make sense?
LostInTheFold 5 Posted March 6 Posted March 6 I wanted to let you know that I moved the "extras" titles into the "trailers" folder and that seemed to solve the problem. So the summary of this is that the trailers folder does not have the same issue as the extras folder. Perhaps someone could look into how those two folders are treated. From my perspective, I have found a work around although it isn't the most perfect. I can live with it. If you do end up fixing it, posting to this thread would be great.
Luke 42287 Posted March 23 Posted March 23 On 3/6/2026 at 12:33 AM, LostInTheFold said: I wanted to let you know that I moved the "extras" titles into the "trailers" folder and that seemed to solve the problem. So the summary of this is that the trailers folder does not have the same issue as the extras folder. Perhaps someone could look into how those two folders are treated. From my perspective, I have found a work around although it isn't the most perfect. I can live with it. If you do end up fixing it, posting to this thread would be great. Hi, but now you can no longer get to those extras, right?
LostInTheFold 5 Posted March 23 Posted March 23 Ah, I see. I didn't check that when I put them there or when I had the trailers. thanks for getting back to me. I will split this out even if it isn't really what i wanted. I guess i can duplicate the extras out to each folder. The trailers folder had 1 trailer for each movie, so i can split that. Thanks again for helping me out on this, you have been really helpful to me on each of my issues i have had. 1
