Ale229 2 Posted November 13, 2025 Posted November 13, 2025 Hi, I’ve installed Emby app for Android TV on my Sony Bravia, trying to play a couple of mkv file transcoded with very high bitrate but they doesn’t start. Used my LG tv and they worked fine, anyone could help me? I’m not very practical about this app or the codec I should use, everything is updated (Emby Server, app and tv)
ebr 16335 Posted November 13, 2025 Posted November 13, 2025 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Giorgina87 0 Posted November 13, 2025 Posted November 13, 2025 (edited) Sorry, posted from wrong account Edited November 13, 2025 by Giorgina87
Ale229 2 Posted November 13, 2025 Author Posted November 13, 2025 2 hours ago, ebr said: Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! Hi, ok, I’ll Try: So, I was on my Android Tv, trying to reproduce Lord Of The Rings (in Italian), the playback doesn’t start. On screen there’s a blu circle (as if it’s loading) but the movie doesn’t start. The movie works on Lg TV on the same net and on the web player on my MacBook. The log was sent at 18:36 (Italy Time) User is Ale (I don’t’ know if on the server is saved as Ale229). I have the same problem with all the trilogy of Lord of the Rings and Costantine. If you need I can send the info of the file using MediaInfo.
Luke 42243 Posted November 13, 2025 Posted November 13, 2025 HI there, please attach the emby server log as well. thanks.
ebr 16335 Posted November 14, 2025 Posted November 14, 2025 Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
Ale229 2 Posted November 14, 2025 Author Posted November 14, 2025 Hi, sorry if it takes long @Lukei don’t know how Inca attach the log, I’m using on tv @ebrI tried yesterday before writing here but had the same problem unfortunately. Yesterday I was able to play the video clicking on the line before the file info in the menu at the very right of the screen, probably it transcoded the video.
Luke 42243 Posted November 17, 2025 Posted November 17, 2025 Quote @ebrI tried yesterday before writing here but had the same problem unfortunately. @Ale229what version number did you try?
Ale229 2 Posted November 19, 2025 Author Posted November 19, 2025 On 11/17/2025 at 11:55 PM, Luke said: @Ale229what version number did you try? I tried the last I found on Play Store. I have another problem, if I am at home I’m able to play, outside at my girlfriend house and at my parents house I’m not able to access anymore. I know it’s a different problem, just to not create a new post.
Luke 42243 Posted November 19, 2025 Posted November 19, 2025 Hi, what is the exact version number of the app?
Ale229 2 Posted November 20, 2025 Author Posted November 20, 2025 11 hours ago, Luke said: Hi, what is the exact version number of the app? The one for Android TV is 2.1.23g, the Android one was 3.5.16
Luke 42243 Posted November 21, 2025 Posted November 21, 2025 Ok. Hi there, please attach the Emby server log from when the problem occurred: How to Report a Problem Thanks!
Ale229 2 Posted November 23, 2025 Author Posted November 23, 2025 I don’t know how to get the log from the Android Tv app
FrostByte 5454 Posted November 23, 2025 Posted November 23, 2025 (edited) 2 hours ago, Ale229 said: I don’t know how to get the log from the Android Tv app ebr gave you a link to the instructions on how to send logs from the AndroidTV app in his first post. Edited November 23, 2025 by FrostByte 1
Ale229 2 Posted November 23, 2025 Author Posted November 23, 2025 4 hours ago, FrostByte said: ebr gave you a link to the instructions on how to send logs from the AndroidTV app in his first post. This right? Emby for Android TV/Fire TV and Emby for Roku Logs These apps have the option to send an app log to us electronically. You enter the settings page and turn on the "Debug Options". Now there will be a new tile on your home page settings row (or menu option on the user menu at the top) labelled "Send Log". Reproduce your problem and then use this button to send the log. Then add the following information to your report in the forum: Exactly what you were doing and what happened. Include the name of whatever you played if it is a playback problem The time you sent the log (in Eastern Time please - UTC -5) The name of the Emby user on the local server that was logged in at the time I’ve sent in the post after, I did solve the problem about the playback more or less, have some little problems with the remote connection. Trying to assign a static Ip on the server at the moment. 1 1
