stigerj 0 Posted November 11, 2025 Posted November 11, 2025 My family use to be able to connect with no problem. But now nobody can connect except me from within my own network. What do I need to do to be able to get them connected to my Emby?
Abobader 3491 Posted November 11, 2025 Posted November 11, 2025 Hello stigerj, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Happy2Play 9814 Posted November 11, 2025 Posted November 11, 2025 Have you checked everything in the KB? External Connections
pwhodges 2039 Posted November 11, 2025 Posted November 11, 2025 One thing to note is that in some circumstances modern browsers will try to force ssl (https) connections from their end. It is possible in their settings to override this to re-enable access using http. Paul
Luke 42288 Posted November 11, 2025 Posted November 11, 2025 14 hours ago, stigerj said: My family use to be able to connect with no problem. But now nobody can connect except me from within my own network. What do I need to do to be able to get them connected to my Emby? Hi there, what exactly happens when they try to connect?
brothom 211 Posted November 11, 2025 Posted November 11, 2025 14 hours ago, stigerj said: My family use to be able to connect with no problem. But now nobody can connect except me from within my own network. What do I need to do to be able to get them connected to my Emby? If it used to work, but now it doesn't, it sounds like there might be something wrong in the communications. Did you maybe reset your router or so, causing the ports to no longer be forwarded to your server? Did you add a new device in between since last time they were able to connect? All in all your issue sounds like a network issue and as @Lukementioned we would like to know "how" your users are trying to connect to you (via a ip, domain, via app or browser, etc). Please provide as much information as possible.
