Radio Channel will not play from LiveTV EPG
I have added an audio only radio channel to my EPG in the M3U file.  The url plays in VLC, but will not play in Emby clients, on either windows or android devices.
The channel showes up in the EPG and I can selected it to play.  I get the spinning wheel for some time and then an error that the channel can't be played.
Here's the M3U entry.
#EXTINF:-1, tvg-chno="454" tvg-id="Country Radio" tvg-name="Country Radio" group-title="Country Radio"
https://icecast-stream.wbur.org/wbur_www
To test, I've tried many different URL's in the M3U FIle incase it was the source.   But none will play
embyserver.txt ffmpeg-transcode-3946d98d-7552-4ba7-be13-60de198df2fa_1.txt
Hi, are you able to update to a newer version of Emby Server and see if that helps?
  • 3 months later...
learch74
The newest version of Emby server finally worked :)   Thanks for the hard work.
  • Thanks 1
